Heat in cabin for driver side defrost, Driver side vent/heat valve question… |
jim_hoyland |
Sep 3 2021, 06:00 AM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I have good heat into the cabin; when the dash control is set to floor. But, when the control is set to defrost, I get little or no flow on drivers side. A fair amount gets to the passenger side.
I’m lookin for advice on how to reset the cable/valve connection first. My second thought is something fell into the defrost vent - like a parking stub ? Can the valve be removed and opened up without removing the fuel tank ? A couple of picture attached for a view ( not my car ) but might help Attached image(s) |
mepstein |
Sep 3 2021, 06:15 AM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Can you remove the paper tube in the footwell from the diverter and enter it from below?
Just enough to stick a vacuum hose up into it. |
jim_hoyland |
Sep 3 2021, 06:18 AM
Can you remove the paper tube in the footwell from the diverter and enter it from below? Just enough to stick a vacuum hose up into it. I tried that and set the Vac to blow; footwell vent is fine, defrost vent weak. Attached image(s) |
76-914 |
Sep 3 2021, 08:46 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Jim, I took mine apart when I added AC and found a pencil in it. I'd previously wondered why the slide control would only move 1/2 way across. That entire piece and the 90 can be removed with the tank in place. IIRC - its been 5 years - I needed to remove the vent louver in order to remove the 90. Can't remember why now. But yes, the vent 90 and the junction box on the left side comes apart with tank in place. (IMG:style_emoticons/default/beerchug.gif)
EDIT: Just remembered that there are 2 nuts you need to remove behind the louver in order to remove that assembly. And I believe there are 2 more you access from below. |
jim_hoyland |
Sep 3 2021, 10:14 AM
I see the nuts under the dash. The red slider does move all the way over to the right; it might not be moving the valve enough ?
Dam hard to see what the range of motion is from outside the valve Attached thumbnail(s) |
jim_hoyland |
Sep 3 2021, 10:15 AM
The closed position - Defrost position
barefoot |
Sep 3 2021, 12:16 PM
Senior Member Group: Members Posts: 1,281 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
This may help chasing cable connections:
Heater___Ventilation_control_2.pdf ( 91.07k ) Number of downloads: 28 |
jim_hoyland |
Sep 3 2021, 12:23 PM
This may help chasing cable connections: Heater___Ventilation_control_2.pdf ( 91.07k ) Number of downloads: 28 Thanks ! I double checked, cables are right. |
Root_Werks |
Sep 3 2021, 12:47 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Good thread I'll bookmark for later. My tank is out for painting along with most of this stuff. Oddly, never taken all this out before. It'll be interesting putting it all back together.
jim_hoyland |
Sep 3 2021, 12:56 PM
Good thread I'll bookmark for later. My tank is out for painting along with most of this stuff. Oddly, never taken all this out before. It'll be interesting putting it all back together. I would mock it all up on the bench and see how it works. Then you can “preset” the three cables connections. And, the nuts on the valves that hold the cables are 7mm. |
jim_hoyland |
Sep 3 2021, 12:58 PM
Root_Werks |
Sep 3 2021, 02:11 PM
Couple of other links: http://www.914world.com/bbs2/index.php?showtopic=86942 https://914electric.wordpress.com/2011/03/18/take-the-heat/ @Root_Werks Perfect, thanks! |
Lo-Fi Version | Time is now: 8th June 2024 - 08:33 AM |
