> Pic request 914-6 conversion using CIS throttle, Thought I saved one from a past search - can't find it
nditiz1
post Sep 15 2021, 06:49 AM
I will be using the patrick motorsports linkage and I am already seeing an issue. The sheet metal from restoration design looks to be using the stock location for carbs which pushes the throttle closer to the center of the engine and has the ball on the inside. CIS throttle has it on the outside. I believe some needed to drill out the ball and tap it on the opposite side. Did they also need to drill a new hole? Did anyone get it working with less effort? Maybe just drill a hole further towards the outside of the engine and not mess with the ball on the throttle shaft. Show me what you did if you can, I'm a visual learner (IMG:style_emoticons/default/beer3.gif)
Thanks all!
Replies(1 - 18)
Root_Werks
post Sep 15 2021, 08:41 AM
Village Idiot
Here's a pic of my 2.7 with CIS. It uses a 4cyl cable. I cannot claim credit for the bracket. PO made a little bracket which allowed the use of the cable. Only mod on my part was drilling a hole in the 914-6 tin, adding a grommet for the cable to run through.
Tdskip
post Sep 15 2021, 09:19 AM
Bump for even more pictures...and a thank you to @Root_Werks
post Sep 15 2021, 09:52 AM
Resident German
Search for the build thread of the late Jeff Tucker (Jeffs9146), he had tons of good info in there.
VegasRacer
post Sep 15 2021, 10:16 AM
ELVIRA
nditiz1
post Sep 15 2021, 10:48 AM
Thanks @SirAndy
@VegasRacer - John did you drill a new hole? Looks like everything is stock. Did you use the existing hole or drill a new one?
Cairo94507
post Sep 15 2021, 10:53 AM
Michael
VegasRacer and Root_Werks both have clean installs. (IMG:style_emoticons/default/beerchug.gif)
VegasRacer
post Sep 15 2021, 11:06 AM
ELVIRA
QUOTE(Cairo94507 @ Sep 15 2021, 09:53 AM) *
The PO did the conversion. (IMG:style_emoticons/default/smash.gif) No extra holes that I am aware of.
nditiz1
post Sep 15 2021, 12:16 PM
Do you think you can get a shot of looking at where it passes through the rear engine tin?
Root_Werks
post Sep 15 2021, 01:58 PM
Village Idiot
I think you can use a 914-6 bell crank with most of the factory CIS linkage. It's super close to 914-6 carbs. There was one 914-6 CIS conversion I recall doing using a 914-6 bell crank and slightly modified rod. Turned out very nice and factory looking.
Only reason my 914-6 uses a 4cyl cable is because it was already done and works well.
nditiz1
post Sep 15 2021, 03:47 PM
This is the issue with it lining up.
VegasRacer
post Sep 15 2021, 11:18 PM
ELVIRA
QUOTE(nditiz1 @ Sep 15 2021, 11:16 AM) *
This is the only photo I could find in my files of the rear engine tin.
Steve
post Sep 15 2021, 11:25 PM
QUOTE(VegasRacer @ Sep 15 2021, 10:18 PM) *
What’s the red box for?
VegasRacer
post Sep 16 2021, 12:47 AM
ELVIRA
AMB Racing Transponder. Attached Image
ClayPerrine
post Sep 16 2021, 06:25 AM
QUOTE(VegasRacer @ Sep 16 2021, 01:47 AM) *
Why would you put the transponder that far back in the car? You would want it on the front bumper... Just in case you go neck and neck with another car across the line. If he has his transponder on the front bumper, and you have it in the engine compartment, he is going to win because his transponder crossed the line first.
Clay
ClayPerrine
post Sep 16 2021, 06:33 AM
Here are some pictures from an old thread on a CIS 914. The previous owner used an Audi airbox to replace the Porsche one, and that allowed it to fit in the 914 engine compartment.
(IMG:http://www.914world.com/bbs2/uploads/post-2-1129560305.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-2-1129560335.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-2-1129560365.jpg)
The whole thread on the system is HERE.
VegasRacer
post Sep 16 2021, 09:41 AM
ELVIRA
QUOTE(ClayPerrine @ Sep 16 2021, 05:25 AM) *
You are correct Clay . . . . IF I was using the car for wheel to wheel competition.
It makes no difference for DE events and collecting lap times.
nditiz1
post Sep 16 2021, 10:32 AM
I just drilled a hole next to the factory throttle location. It should do the trick if I offset PMS throttle further towards the passenger side to line up perfectly.
VegasRacer
post Sep 16 2021, 10:37 AM
ELVIRA
- Lo-Fi Version Time is now: 15th October 2026 - 11:31 PM
