electrical - where to start looking? |
bandjoey |
Sep 16 2021, 01:30 PM
bandjoey Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I was taking the 914 out today for a safety inspection to get new license plate sticker. Started the car and checked all the lights and they all worked perfectly. Shut down the car and a few minutes started up the motor to leave.
First thing i see is the radio flashing like crazy and no 'idiot' So I checked the lights again and here's the results: Both headlights on low beam. Right goes to high and left stays on low Fog lights work as they should No turn signals but emergency flashers work ok Dash lighting is fine (with headlights on) but no parking brake light & generator light stays on Tail lights on ok with headlights on but no brake lights No radio All the fuses are ok but definitely a short or a failed component What is a good starting place you think I to trace this down? |
914e |
Sep 16 2021, 01:44 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
It seems to be affecting many systems. I would start looking for loose grounds, and bad connections at all the 10-12 gauge power cables. Off the top of head they are all red and yellow
Spoke |
Sep 16 2021, 07:10 PM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Both headlights on low beam. Right goes to high and left stays on low Fog lights work as they should It seems impossible that one headlight could go hi beam while the other is low beam. See below that both low beams come from the same wire. Likewise both high beams come from the same wire. Attached thumbnail(s) |
Spoke |
Sep 16 2021, 07:14 PM
Dash lighting is fine (with headlights on) but no parking brake light & generator light stays on @bandjoey So the GEN light stays on all the time? Did you spin all the fuses? Did you take each fuse out and measure their resistances? Check fuse 9 to see that it has power on both sides of the fuse. fuse 9 powers the GEN light. Check each side of fuse 9 to chassis ground. Both sides should be 14V. Attached thumbnail(s) |
Steve |
Sep 16 2021, 07:21 PM
914 Guru Group: Members Posts: 5,619 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Stab in the dark, but try swapping the accessory relay with the horn or fog relay.
When you pull the panel to swap the relays look for loose wires and check the ground connections. |
bandjoey |
Sep 17 2021, 11:40 AM
While tracing down grounds I found the problem. I won LED headlights from VintagecarLED's at I think Okteenerfest several years ago. Their lights have a pigail plug in socket plus a box of some sort on a separate wire. Metal and plastic box. Somehow the electrical tape I had installed came apart and it was shorting on the headlight frame. Re-taped everything, reinstalled, and everything back to normal. Thanks for the suggestions. !!
Attached image(s) |
Lo-Fi Version | Time is now: 16th June 2024 - 02:03 PM |
