bumper bolt strength, will 8.8's be strong enough for temporary use? |
914lover17 |
Sep 20 2021, 06:14 PM
Newbie Group: Members Posts: 45 Joined: 11-June 21 From: Kitchener-Waterloo Member No.: 25,622 Region Association: Canada |
My bolts are in pretty bad shape, looks like they have been cut down from unoriginal longer bolts. Some aren't fitting, even with the bumper off.
I am going to lightly tap the nuts and wanto get replacement bolts/rubber biscuit spacers. Are the 8.8 class m8 x 40mm bolts from the hardware store good enough for temporary use while I order the correct 10.9 class ones? the ones inside it now are 9.8. example of correct OEM: https://www.justkampers.com/n0103404-m8-x-4...rious-uses.html Temporary option: https://www.homedepot.ca/product/paulin-m8-...ated/1000135048 |
914Sixer |
Sep 20 2021, 06:52 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Factory bolts were 8.8 and plenty strong.
mepstein |
Sep 20 2021, 07:28 PM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Some people use threaded studs to make hanging the bumper easier.
bkrantz |
Sep 20 2021, 07:31 PM
914 Guru Group: Members Posts: 7,804 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Some people use threaded studs to make hanging the bumper easier. But then they miss out on the fun of single-handed supporting a bumper in place while trying to get a bolt on each side started. (IMG:style_emoticons/default/headbang.gif) |
mepstein |
Sep 20 2021, 07:37 PM
Some people use threaded studs to make hanging the bumper easier. But then they miss out on the fun of single-handed supporting a bumper in place while trying to get a bolt on each side started. (IMG:style_emoticons/default/headbang.gif) Actually not to hard if you can find a large cardboard box to sit it on. Also works well for removing. |
windforfun |
Sep 20 2021, 08:39 PM
Senior Member Group: Members Posts: 1,838 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Some people use threaded studs to make hanging the bumper easier. But then they miss out on the fun of single-handed supporting a bumper in place while trying to get a bolt on each side started. (IMG:style_emoticons/default/headbang.gif) Actually not to hard if you can find a large cardboard box to sit it on. Also works well for removing. Call your neighbor. Those bolts pictured above should sue for severe abuse. I guess some folks need help. |
Rand |
Sep 20 2021, 08:49 PM
What bumpers? never mind, they will even hold the rbbbb
914e |
Sep 21 2021, 08:45 AM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
These are not an 8.8 but Belmetric has 10.9 Flangehead bolts
https://www.belmetric.com/8mm-c-2_1208_1221...ull-p-7187.html |
Shivers |
Sep 21 2021, 09:59 AM
Senior Member Group: Members Posts: 2,431 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
914sgofast2 |
Sep 21 2021, 10:09 AM
Senior Member Group: Members Posts: 623 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Threaded studs are the only way to go!
914lover17 |
Sep 21 2021, 12:00 PM
What bumpers? never mind, they will even hold the rbbbb Just consider it a trim panel, you really don't want to bump it. 8.8's are fine My bumpers fit pretty tight. I have to crank on the bolts pretty hard to bring them into the correct position. That's where my strength concern came in. |
Olympic 914 |
Sep 21 2021, 12:01 PM
Group: Members Posts: 1,676 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Threaded studs are the only way to go! (IMG:style_emoticons/default/agree.gif) At least for the top two. I cut screwdriver slots in the studs, then switch them out for bolts after the bumpers are hung. |
914lover17 |
Sep 21 2021, 12:25 PM
Threaded studs are the only way to go! (IMG:style_emoticons/default/agree.gif) At least for the top two. I cut screwdriver slots in the studs, then switch them out for bolts after the bumpers are hung. thats a great idea, especially since they are temporary. |
914lover17 |
Sep 27 2021, 10:07 PM
Lo-Fi Version | Time is now: 10th June 2024 - 12:09 AM |
