My bolts are in pretty bad shape, looks like they have been cut down from unoriginal longer bolts. Some aren't fitting, even with the bumper off.
I am going to lightly tap the nuts and wanto get replacement bolts/rubber biscuit spacers.
Are the 8.8 class m8 x 40mm bolts from the hardware store good enough for temporary use while I order the correct 10.9 class ones? the ones inside it now are 9.8.
example of correct OEM:
https://www.justkampers.com/n0103404-m8-x-4...rious-uses.html
Temporary option:
https://www.homedepot.ca/product/paulin-m8-...ated/1000135048
