bumper bolt strength, will 8.8's be strong enough for temporary use? |
914lover17 |
Sep 20 2021, 06:14 PM
Newbie Group: Members Posts: 45 Joined: 11-June 21 From: Kitchener-Waterloo Member No.: 25,622 Region Association: Canada |
My bolts are in pretty bad shape, looks like they have been cut down from unoriginal longer bolts. Some aren't fitting, even with the bumper off.
I am going to lightly tap the nuts and wanto get replacement bolts/rubber biscuit spacers. Are the 8.8 class m8 x 40mm bolts from the hardware store good enough for temporary use while I order the correct 10.9 class ones? the ones inside it now are 9.8. example of correct OEM: https://www.justkampers.com/n0103404-m8-x-4...rious-uses.html Temporary option: https://www.homedepot.ca/product/paulin-m8-...ated/1000135048 |
Lo-Fi Version | Time is now: 18th May 2024 - 07:48 PM |
