Mechanical Cleaning of Center Tunnel, What are your tools and techniques |
seanpaulmc |
Sep 28 2021, 07:40 AM
Member Group: Members Posts: 304 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
There are some good threads already about how to chemically clean and treat the center tunnel. I have not found any with good coverage about tools and techniques to mechanically go after the rust and debris before doing a chemical treatment. Maybe not so much of an issue for the dry and west coast cars but this is not one of those. This is an east coast car that has seen some water and developed rust in there. It needs a good scraping before treating and sealing it.
Would like your experience on what tools, pictures would be great, work well for getting in there to scrub it. Kitchen bottle brush on a long flex tape? And, any suggestions on how to protect the wiring look at the back of the tunnel from the Ospho? Thanks Sean Attached image(s) |
mate914 |
Sep 28 2021, 08:51 AM
Matt Group: Members Posts: 755 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
Change the floor pans. East cost cars have rust in places that removing floor pan is the only way to save it.
Matt |
Cairo94507 |
Sep 28 2021, 09:38 AM
Michael Group: Members Posts: 9,818 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Assess the remainder of the floor pan thoroughly for rust in all of the usual place. Your easiest fix may just be to replace the floor pans. Then you solve that problem correctly and for good as you can then treat all the new metal so rust is likely to not reappear in the next few decades. (IMG:style_emoticons/default/beerchug.gif)
jcd914 |
Sep 28 2021, 07:48 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Mine had loose dirt, grit from blasting, some light surface rust and a few odd nuts & bolts in the tunnel.
I used a shop vac as best I could reach initially, then I used a long wide bottle brush (from brewing equipment) and compressed air through a nozzle. Stuck the vacuum at the back and brushed and blew everything the back. The brush is just soft plastic, so I did not scrape anything loose just helped moved some of the loose stuff. Jim |
partwerks |
Sep 28 2021, 08:23 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Or maybe stick an air compressor nozzle on one end, and vacuum on the other?
930cabman |
Sep 30 2021, 12:20 PM
Advanced Member Group: Members Posts: 3,141 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Is removing the tunnel an option? I have considered it. Replacing the floor pans is not a difficult job, if you have a rotisserie. Otherwise one is completing many plug welds upside down.
BeatNavy |
Sep 30 2021, 01:19 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I agree that replacing the floor pans, especially without a rotisserie, is a PITA. If they are gutted, then of course it is necessary -- they are a major component of structural integrity.
There is a thread here where someone cut the tunnel metal from underneath, cleaned it up, and then welded it back in. It was a pretty slick way to do it. Probably still a PITA, but probably easier than replacing the entire floor pans. |
930cabman |
Sep 30 2021, 02:43 PM
I was thinking of removing sections from the cabin, do what is necessary and welding things up. Too crazy?
930cabman |
Oct 1 2021, 05:38 PM
Can anyone point me to a thread demonstrating cleaning the center tunnel?
Thanks I am considering removing sections from in the cabin to access and welding the pieces back in place. |
bkrantz |
Oct 1 2021, 07:31 PM
914 Guru Group: Members Posts: 7,801 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I suppose if (a great big IF) the tunnel has only surface rust inside, then sticking a high pressure washer nozzle with a right-angle head inside from all openings and all angles might dislodge enough rust and dirt for chemical treatment.
mepstein |
Oct 1 2021, 07:57 PM
914-6 GT in waiting Group: Members Posts: 19,312 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would remove the wire harness from the tunnel, Get a couple long round wire brushes, scrub up the inside of the tunnel with the metal brushes, vacuum, spray brake clean on some rags and inside tunnel, clean as best you can, coat tunnel with etch prime, rust bullet or your favorite preservative.
930cabman |
Dec 14 2021, 12:38 PM
barefoot |
Dec 16 2021, 06:27 AM
Senior Member Group: Members Posts: 1,280 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Lo-Fi Version | Time is now: 5th June 2024 - 11:35 PM |
