What is this body piece..., ...and how do I fix it? |
Rick986 |
Sep 29 2021, 11:40 AM
0-60 in 14 seconds! Group: Members Posts: 141 Joined: 31-August 21 From: NE Ohio Member No.: 25,869 Region Association: Upper MidWest |
These hard plastic pieces on both driver & passenger side are lifting out. They can't be pushed back down with my thumb and I'm wondering if I'll crack them or damage the panels by gently tapping them in.
What's the technical name for this piece and will I cause damage by giving them a tap? Perhaps it's my imagination, but they appear to have lifted more since I received and have been driving the car. Body/panel flex from too much speed in the twisties??? (we have some great roads around here!) Thanks guys! Attached image(s) |
914Sixer |
Sep 29 2021, 11:43 AM
914 Guru Group: Members Posts: 8,887 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
914Rubber has your new ones.
9one4tay |
Sep 29 2021, 12:09 PM
Newbie Group: Members Posts: 25 Joined: 13-January 20 From: Boulder Creek, Ca. Member No.: 23,825 Region Association: Northern California |
Fender Cowl seal
mepstein |
Sep 29 2021, 12:28 PM
914-6 GT in waiting Group: Members Posts: 19,282 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
914rubber has replacements
I would be careful forcing it in. You don’t want to crack the paint. Very few things on a Porsche actually need to be forced into place. I would rather file or sand down the seals a bit until it’s a press fit by hand. They are a cosmetic item so don’t sweat it. |
mmichalik |
Sep 29 2021, 12:34 PM
MikeM Group: Members Posts: 700 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
Also, those channels collect a lot of dirt and debris. Clean them out before you put the replacements in.
My car didn't have a whole lot of rust on it but, it did have it there. |
9146C |
Sep 29 2021, 12:35 PM
Member Group: Members Posts: 228 Joined: 14-September 19 From: US Member No.: 23,460 Region Association: None |
The 914Rubber pieces come longer than required (excess material).
Not knowing "how" to install them, I notched the bottom side on one end so I could install vice grips and pull it through from one end using plenty of silicone lube. No problem doing that I pulled it through from the door toward the trunk on both sides. A very quick installation. |
Rick986 |
Sep 29 2021, 12:51 PM
Thanks everybody!
Thunderchief |
Sep 29 2021, 05:54 PM
Member Group: Members Posts: 145 Joined: 12-August 19 From: Pasadena, CA. Member No.: 23,365 Region Association: Southern California |
I left mine off when I did my repaint. I like it better without
bkrantz |
Sep 29 2021, 08:03 PM
914 Guru Group: Members Posts: 7,772 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
second wind |
Sep 29 2021, 10:56 PM
Senior Member Group: Members Posts: 856 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Leave them out in the sun for couple of weeks as they shrink. Once shrunken down a bit THEN cut them to size....maybe a tad long. new ones look great!
gg |
windforfun |
Sep 30 2021, 10:16 AM
Senior Member Group: Members Posts: 1,801 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
windforfun |
Sep 30 2021, 10:38 AM
Mikey914 |
Sep 30 2021, 11:01 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We made the new ones from rubber not PVC. It will be a simple install with some soapy water. Can also be easily removed and reinstalled if you want to blow out the track every so often.
Lo-Fi Version | Time is now: 23rd May 2024 - 07:54 AM |
