Oil Cooler Fan, Oil Cooler Fan |
dirk2056 |
Sep 30 2021, 10:17 AM
Member Group: Members Posts: 93 Joined: 31-July 17 From: cincinnati/Eastside Member No.: 21,304 Region Association: Middle East |
(IMG:style_emoticons/default/idea.gif) Was going through my stash of stuff and found this marine fan used to clear fumes under in engine compartment. The fan is rated at 400 CFM which is very powerful for the size.
The idea is install under stock oil cooler? It fits very nicely between fan shroud and oil filter. What do you think?? |
ClayPerrine |
Sep 30 2021, 10:21 AM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I would check the temp rating on the plastic for that fan. It may melt.
Clay |
barefoot |
Sep 30 2021, 10:23 AM
Senior Member Group: Members Posts: 1,276 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I expect the engine fan provides MUCH more cooling than this fan would produce.
914Mels |
Sep 30 2021, 02:46 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Isn't it going to interfere with the engine mount bar?
9146C |
Sep 30 2021, 02:55 PM
Member Group: Members Posts: 228 Joined: 14-September 19 From: US Member No.: 23,460 Region Association: None |
I don't think a marine bilge blower is designed to be a continuous duty fan.
maf914 |
Sep 30 2021, 03:33 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I expect the engine fan provides MUCH more cooling than this fan would produce. Does anyone know how much air the Type 4 fan moves. We need a CFM versus RPM curve. If the bilge pump fan could be mounted and ducted to the oil cooler I wonder if the 400 CFM would significantly alter the airflow to the four cylinders. (IMG:style_emoticons/default/idea.gif) |
moto914 |
Sep 30 2021, 03:37 PM
Newbie Group: Members Posts: 43 Joined: 27-February 17 From: Greenville SC Member No.: 20,878 Region Association: South East States |
Had a similar idea. Concluded that pushing air in would be against the flow from the engine fan and wouldn't be beneficial for the cooler. Pulling air out would have a negative effect for the cylinders.
Lo-Fi Version | Time is now: 23rd May 2024 - 06:30 AM |
