front windshield seal installation SOLVED |
Medtner3 |
Oct 1 2021, 06:38 PM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
Edit: This is a PITA I used various tools but the one that worked best was soap plus large flathead screwdriver
and the runs are very scratched, some are fresh from using the screwdriver which is why I hated even trying it but how to get rid of fine scratches now? SOLVED How the heck do you get the new rubber seal to slide into the chrome trim pieces? Is there a secret or a trick to this? I can only get mine in about two inches on the driver's side and 1/2 on the passenger side? Soap and water? vaseline? |
RiqueMar |
Oct 1 2021, 07:16 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
How the heck do you get the new rubber seal to slide into the chrome trim pieces? Is there a secret or a trick to this? I can only get mine in about two inches on the driver's side and 1/2 on the passenger side? Soap and water? vaseline? @Medtner3 - Are you talking about the Main Targa Seal? If so, I did a write-up on my build thread. Follow this link to my thread, post #851 about halfway down. > Link here |
bkrantz |
Oct 1 2021, 07:22 PM
914 Guru Group: Members Posts: 7,809 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Like Enrique and most others, I found it impossible to slide the A-pillar seals into the tracks, but fairly easy to place the inner edge into the track and then massage the outer edge into the track, from top to bottom.
iankarr |
Oct 1 2021, 08:10 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
They don’t slide. Even though they look like they should. The back side of the seal goes in the channel and you push the front side in, bit by bit using liquid soap as lube.
Mikey914 |
Oct 1 2021, 08:31 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
For the most part you don't want to slide as rubber has memory and after you cut it it will return to the unsurpassed state. Expansion and contraction as well as vibration will see to that.
This might be helpful too https://914rubber-tk.com/doku.php |
Medtner3 |
Oct 2 2021, 08:17 AM
How the heck do you get the new rubber seal to slide into the chrome trim pieces? Is there a secret or a trick to this? I can only get mine in about two inches on the driver's side and 1/2 on the passenger side? Soap and water? vaseline? @Medtner3 - Are you talking about the Main Targa Seal? If so, I did a write-up on my build thread. Follow this link to my thread, post #851 about halfway down. > Link here Thank you great post! |
Medtner3 |
dr914@autoatlanta.com |
Oct 2 2021, 08:40 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
open the pinches in the track and lubricate the track and seal with silicone GREASE and slide down the track
RiqueMar |
Oct 2 2021, 05:33 PM
How the heck do you get the new rubber seal to slide into the chrome trim pieces? Is there a secret or a trick to this? I can only get mine in about two inches on the driver's side and 1/2 on the passenger side? Soap and water? vaseline? @Medtner3 - Are you talking about the Main Targa Seal? If so, I did a write-up on my build thread. Follow this link to my thread, post #851 about halfway down. > Link here Thank you great post! Happy to help! (IMG:style_emoticons/default/bye1.gif) |
Medtner3 |
Oct 2 2021, 07:47 PM
open the pinches in the track and lubricate the track and seal with silicone GREASE and slide down the track How the heck do you get the new rubber seal to slide into the chrome trim pieces? Is there a secret or a trick to this? I can only get mine in about two inches on the driver's side and 1/2 on the passenger side? Soap and water? vaseline? Thank you George |
Lo-Fi Version | Time is now: 13th June 2024 - 03:21 AM |
