Need your help, Oil temp sender |
qa1142 |
Jul 26 2005, 07:05 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Ok, so ~ 10 days ago I installed temp sender....
Taco plate leaked like crazy. So tonight I drained oil and pulled it back apart. choices: 1) re-install with new gasket and more sealer 2) put old cover back on and install the temp sender I got that replaces drain plug. Issue taco plate sender says 200 deg and drain plug says 150 deg. So what do I do? I could swap temp for oil presure too.... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) What would you do? |
ArtechnikA |
Jul 26 2005, 07:14 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
first - izzat F or C? if it's C (as i expect, because 150F oil temp max is silly...) either will be enough - but only one will be ACCURATE with your gauge head; pick the one that is. i'd go for 3) straighten/flatten the taco plate (which gets its name because it WARPS LIKE CRAZY) until it WILL seal, then use the correct number of the correct gaskets and torque it the correct amount. |
SirAndy |
Jul 26 2005, 07:20 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
and don't forget to get 2 new copper crush washers for the 10mm bolts.
they're one time use only! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
qa1142 |
Jul 26 2005, 07:24 PM
I have new washers and a gasket for between the plates.
Why even put outer plate on? Bet it would seal easy without it... Thoughts on that? |
Allan |
Jul 26 2005, 07:52 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
When I did mine I really couldn't figure that out as well. Seems like it does'nt really seal anything. I put it in anyway just because.
But, I have no leaks from the taco plate. |
mihai914 |
Jul 26 2005, 08:05 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Are you using a paper gasket or an o-ring for the plate?
qa1142 |
Jul 26 2005, 08:47 PM
Ok
Did it proper... (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) yes O'ring, then plate, then sealer, then gasket, then sealer, then top plate (or bottom I guess) Re-filled oil, we'll see tomorrow Where is our crossed fingers smilie? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
ematulac |
Jul 27 2005, 12:46 AM
914 addict Group: Members Posts: 540 Joined: 24-November 03 From: Palmdale, CA Member No.: 1,382 |
I just went through the same thing.
Did pretty much what you did, but I had a to make my own gasket to go between the plates. I used lots of sealant, and replaced the crush washers with larger fiber washers. I ran the car for a few minutes and it seemed to be leak free. The real test will be the drive to work tomorrow :crosses fingers smiley:. |
SirAndy |
Jul 27 2005, 10:57 AM
it protects the sender and wire ... i run mine without the outer plate, werks (and seals) just fine ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
qa1142 |
Jul 27 2005, 07:25 PM
Still leaks (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
I cleaned my drip pan and will see how bad it is. next I'll try without outer plate (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
qa1142 |
Jul 31 2005, 03:49 PM
Well
Oil sure is clean when you change it every week (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Re Re Re sealed the temp sender plate, this time no outer cover. I'll find out soon enough - This is it before (or better to say till after) MWC |
Lo-Fi Version | Time is now: 7th June 2024 - 06:07 AM |
