Aux. Heater Blower Power-1975 1.8, Electrical Issues |
ballsyfacts914 |
Oct 3 2021, 04:23 PM
Member Group: Members Posts: 82 Joined: 28-August 19 From: East Bay Region-SF Bay Area Member No.: 23,413 Region Association: Northern California |
Hi All,
I haven't posted in awhile, after having some work done on the 914, I have been enjoying the heck out of the good weather driving around. I also have been make other small adjustments and finding the parts that have been missing...like the auxiliary heater blower. I installed my nice used heater blower and it wouldn't turn on. After double checking my connections and that everything was in the right place, I tested the wires from the harness and there was no power. I will admit now that electrical work is my weak point so I am still learning. I deep-dived and found a few things amiss, see photos below. The first is of the relay board, I know several of the circular plug in relays(?) are missing. There is also a rogue yellow wire connected to a rogue blue wire, haven't seen anything that tells me why that was done. The second photo is of the harness and everything looks close but I think a few things may be wrong, namely wire colors not matching. The other thing, the wires that I used to hook into the blower split off from the main harness and don't seem to be connected to the relay board. I would love any advice on what I need part wise, if I should replace anything, and/or what I need to redo wire wise. The second photo will be posted, it was too big to add here. Thanks in advance, really appreciate this community! |
ballsyfacts914 |
Oct 3 2021, 04:24 PM
bzettner |
Oct 3 2021, 04:38 PM
Member Group: Members Posts: 211 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region |
Without my Haynes book in front of me, I'm not sure which relay it is, but one of them is for the heater IIRC. One is for the rear window defogger/de-icer, IIRC.
Others will chime in. Do you have an extra relay(s) to plug in one or both of the empty locations and try? |
ballsyfacts914 |
Oct 3 2021, 05:14 PM
Without my Haynes book in front of me, I'm not sure which relay it is, but one of them is for the heater IIRC. One is for the rear window defogger/de-icer, IIRC. Others will chime in. Do you have an extra relay(s) to plug in one or both of the empty locations and try? I do not but I am going to find some now! Thank you! |
bzettner |
Oct 3 2021, 05:27 PM
Is your car fuel injected still? One of your missing relays has to do with FI. The rear most receptacle is for the heater.
ballsyfacts914 |
Oct 3 2021, 05:54 PM
NARP74 |
Oct 3 2021, 06:03 PM
Senior Member Group: Members Posts: 1,073 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
According to this, your car should not even run.
https://bowlsby.net/914/Classic/zTN_Elect_RegulatorPlate.jpg |
ballsyfacts914 |
Oct 8 2021, 04:08 PM
According to this, your car should not even run. https://bowlsby.net/914/Classic/zTN_Elect_RegulatorPlate.jpg (IMG:style_emoticons/default/lol-2.gif) Of course it shouldn't! Totally does though, appreciate the diagram, thank you |
ballsyfacts914 |
Oct 8 2021, 04:11 PM
Hi All-new relays arrived, put one in and the heater blower works!
NARP74 included a diagram, would appreciate any additional comments/recommendations. Now onto all the other heater parts missing from the car. Thanks again! |
NARP74 |
Oct 8 2021, 04:47 PM
Take a look behind your speaker covers in the corners. When I pulled mine to blow dust out, I saw gaping holes in the tubes going into the front trunk. heat was not making it where it was supposed to go. Good luck and keep posting. My front blower does not work so that is on my list.
Actually everything is on my list! |
ballsyfacts914 |
Oct 8 2021, 05:53 PM
Take a look behind your speaker covers in the corners. When I pulled mine to blow dust out, I saw gaping holes in the tubes going into the front trunk. heat was not making it where it was supposed to go. Good luck and keep posting. My front blower does not work so that is on my list. Actually everything is on my list! Will do and appreciate the info. I have a new front air blower to put in, old still works though so I may not touch unless I have to. Thanks for the speaker tip too. I have slowly but surely learned everything is on the list too. Good luck! |
Lo-Fi Version | Time is now: 6th June 2024 - 11:27 PM |
