Sound of a worn angle drive?, Trying to figure out a sound I hear that is not wheel bearings? |
second wind |
Oct 4 2021, 07:40 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hello teeners.....I have been trying to pinpoint a sound I hear coming from the back of my car.....sounds like a pulsing wurrrr.....at first i thought worn wheel bearing but since there is no grinding sound of any kind I think it is something else....any ideas
? I am starting to think tranny sound....but going down hill with engine off and out of gear still made the sound....or angle drive and/or speedo cable or rpm cable....please advise....thank you my brothers and sister.... gg |
Mikey914 |
Oct 5 2021, 01:12 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
low trans fluid?
bdstone914 |
Oct 5 2021, 06:21 AM
bdstone914 Group: Members Posts: 4,534 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If the angle drive is worn it will be loose when you grab the part that attaches to tbe cable.
second wind |
Oct 5 2021, 11:39 AM
Superhawk996 |
Oct 6 2021, 06:44 AM
914 Guru Group: Members Posts: 5,889 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Not sure what goal is. (IMG:style_emoticons/default/idea.gif)
Simply going down hill with gears disengaged and engine off it still isn't going to be quiet - you'll still hear a variety of noises. Tire tread noise Transmission gear mesh -- there are several gears that are constatntly meshed even in neutral. Transmission bearing noises. Wheel Bearing noises CV joint noises Speedo cable noises Wind noises Squeeks/Rattles/Groans from suspension compliances What is the problem your trying to solve? |
second wind |
Oct 6 2021, 10:41 AM
Not sure what goal is. (IMG:style_emoticons/default/idea.gif) Simply going down hill with gears disengaged and engine off it still isn't going to be quiet - you'll still hear a variety of noises. Tire tread noise Transmission gear mesh -- there are several gears that are constatntly meshed even in neutral. Transmission bearing noises. Wheel Bearing noises CV joint noises Speedo cable noises Wind noises Squeeks/Rattles/Groans from suspension compliances What is the problem your trying to solve? Thank you for your reply....I think the problem is my anxiety over what is making the sound? Given the list of sounds you just mentioned maybe the sound I am comcerned over is just how a 914 sounds? Car runs great and handles great but I am unsure of the source of the sound(s). I might be worrying over nothing. Thank you again. gg |
Superhawk996 |
Oct 6 2021, 11:09 AM
(IMG:style_emoticons/default/piratenanner.gif) Well that's easy then. Just drive and enjoy it.
If its just a subtle noise it likely is normal mechanical noise and not serious. These are 50 year old cars that were desgned and manufactured in a time where noise, vibration, and harshness (NVH) wasn't much of concern. Not at all like modern vehicles with highly engineered accoustical treatments to minimize noise to a level that would have impossible to achieve in 1970. When something serious breaks, it'll be obvious. (IMG:style_emoticons/default/laugh.gif) Go (IMG:style_emoticons/default/driving.gif) and know that you get to do what I can't do for at least another year. |
type2man |
Oct 6 2021, 07:08 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
The way to find out if a wheel bearing is bad is to coast in neutral at about 35 mph and then wiggle the steering wheel side to side. This causes the rear wheel bearing to have load and make more noise than normal. If the noise changes when you sway slowly from left to right the bearings are worn. Another way to check for worn rear bearings is to put the rear in the air and roll the rear wheels at 40 mph in 5th. Put your fingers on the rear coil spring. Both springs should feel smooth. If one feels rough, the bearing is bad.
Lo-Fi Version | Time is now: 5th June 2024 - 01:11 PM |
