LED headlights |
LED headlights |
partwerks |
Oct 20 2021, 08:09 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Which would be the best plug n play led headlights to use?
tazz9924 |
Oct 20 2021, 08:22 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
BillJ |
Oct 20 2021, 08:37 PM
Senior Member Group: Members Posts: 1,116 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
I used vintageleds.com. really happy
VegasRacer |
Oct 20 2021, 10:04 PM
ELVIRA Group: Benefactors Posts: 8,524 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
I witnessed a 914Rubber LED headlight installation in the parking lot at the WCR last weekend. (IMG:style_emoticons/default/biggrin.gif) Super easy swap. (IMG:style_emoticons/default/first.gif)
I was so impressed that I asked about ordering a set. (IMG:style_emoticons/default/smilie_pokal.gif) I was told to wait for the Black Friday sale. (IMG:style_emoticons/default/popcorn[1].gif) |
BillJ |
Oct 20 2021, 10:26 PM
iankarr |
Oct 20 2021, 11:42 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Easy job that makes a huge difference. Here's the video I made about the 914rubber ones...
https://youtu.be/TkTa0JSenk0 |
Cairo94507 |
Oct 21 2021, 04:49 AM
Michael Group: Members Posts: 9,836 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
The LED headlight conversion is a no-brainer regardless of which set you select. I have the Vintage Car LED's in my car and am very pleased with the look, performance and fit. Just be careful to place the small power unit in the headlight bucket where it will not interfere with the headlight movement.
Also, disconnect the battery before you begin playing with the fitment of the small power unit so the headlights don't go up or down as you are turning the knob to check clearance. (IMG:style_emoticons/default/beerchug.gif) |
ConeDodger |
Oct 21 2021, 05:21 AM
Apex killer! Group: Members Posts: 23,616 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
914rubber.com LED right. H4 halogen left. No brainer. And if they are putting them in the Black Friday sale? (IMG:style_emoticons/default/first.gif)
Attached image(s) |
Mikey914 |
Oct 21 2021, 10:44 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The difference between ANY LED and stock is significant. You will wonder why you didn't do it sooner.
FlacaProductions |
Oct 21 2021, 10:49 AM
Senior Member Group: Members Posts: 1,620 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I have the 914Rubber version in their H4 fixtures. Good stuff.
Mikey914 |
Oct 21 2021, 10:58 AM
The only issues with any of these are the fog lights. The LEDs don't draw enough current to trigger the relay to high beam, and when things are rewired it can create problems.
We did an install at WCR with Rick and he had an issue with the fogs. We are providing him with small resistors that should "normalize" the system enough to work as it did with more load. |
gonzo54 |
Oct 21 2021, 01:31 PM
Orange Crush Group: Members Posts: 226 Joined: 10-May 19 From: Seal Beach, CA Member No.: 23,112 Region Association: Southern California |
The only issues with any of these are the fog lights. The LEDs don't draw enough current to trigger the relay to high beam, and when things are rewired it can create problems. We did an install at WCR with Rick and he had an issue with the fogs. We are providing him with small resistors that should "normalize" the system enough to work as it did with more load. Mark, The resistors have not arrived yet so I tried Bruce @bdstone914 and Spoke's thread cutting the white/blue tracer foglight wire at #1 fuse added wire and attached it to Ground. Everything seems to be working today! High and Low beams, Fog light are working now with the LED's on and the Rt Headlight motor is not cycling. Thanks, Rick |
FlacaProductions |
Oct 21 2021, 02:21 PM
Spoke's EP26 relay did it for me.
Mikey914 |
Oct 21 2021, 06:32 PM
Try swapping the left and right so see if it's a relay issue.
partwerks |
Oct 21 2021, 09:34 PM
I witnessed a 914Rubber LED headlight installation in the parking lot at the WCR last weekend. (IMG:style_emoticons/default/biggrin.gif) Super easy swap. (IMG:style_emoticons/default/first.gif) I was so impressed that I asked about ordering a set. (IMG:style_emoticons/default/smilie_pokal.gif) I was told to wait for the Black Friday sale. (IMG:style_emoticons/default/popcorn[1].gif) What day is that going to be? |
Lo-Fi Version | Time is now: 12th June 2024 - 02:35 AM |
