Clubsport32 |
Newbie ![]() Group: Members Posts: 7 Joined: 21-January 20 From: United Kingdom Member No.: 23,849 Region Association: None ![]() |
Hi
I was wondering if anybody had any pointers on how to re-install the side shifter bearing bracket back into the case. I am rebuilding a 914 and the transmission was rebuilt - but sadly part 10 on the picture wasn’t installed back into the transmission. I have replaced all seals, gaskets etc..but not sure of the way to re-install? Can I get it wrong or is there more than one way to locate the teeth… Any help / pointers would be appreciated.. Thanks. Andy Attached image(s) ![]() |
oldie914 |
Member ![]() ![]() Group: Members Posts: 102 Joined: 2-May 10 From: Germany Member No.: 11,680 Region Association: None ![]() |
If you are asking about orientation of parts 14 and 17 when rebuilding the console, put them on as shown in the exploded view. To install the console in the case, make sure the transmission is in neutral (slots in the 3 shift rods should be lined up when you look in the case). Then just put the console in and check to make sure it shifts.
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,530 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
If you can get your hands on Dr. Evils CD, it show it well how to install.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
If you are asking about orientation of parts 14 and 17 when rebuilding the console, put them on as shown in the exploded view. To install the console in the case, make sure the transmission is in neutral (slots in the 3 shift rods should be lined up when you look in the case). Then just put the console in and check to make sure it shifts. one small addition.....if the three slots inside are not in a row (neutral) use a screwdriver to lever them to form a single slot. Normally you should be able to move only one at a time. Then the selector can be angled into place |
Chaznaster |
Member ![]() ![]() Group: Members Posts: 305 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States ![]() ![]() |
I found this article really helpful when removing and replacing the shift selector and the cover.
https://www.pelicanparts.com/techarticles/9...select_seal.htm Shift selector |
Lo-Fi Version | Time is now: 10th June 2024 - 07:08 PM |
