General question about used strut INSERTS |
Literati914 |
Nov 11 2021, 11:50 PM
Senior Member Group: Members Posts: 1,475 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Ive got a couple sets of used front strut inserts that I've been planning to use eventually, one set of Koni's and a set of orange Boge Turbos. I know the rods on these were not sunk to the bottom of the tubes when I stored them several month back (stored standing up). But when I looked today, the rods were in their lowest points on both sets. They have strong resistance upon rebound (by hand) and a little less when pushing them back down but still seems like a good amount. I pulled/pushed them up and down a few times, but they always worked themselves back down eventually when left alone for a while.
my guess is that they shouldn't be collapsed, but then I was thinking that maybe them working through their motions might reinvigorate them (some voodoo magic (IMG:style_emoticons/default/confused24.gif) ). Do they need a rebuild or trip to the dump? . |
mgp4591 |
Nov 12 2021, 02:11 AM
914 Guru Group: Members Posts: 5,382 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I believe Konis can be rebuilt...check the model # of them on their site.
ChrisFoley |
Nov 12 2021, 06:19 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
non-gas shocks will collapse on their own if stored vertically. Nothing wrong with that.
Testing function of a shock absorber requires a pretty vigorous push/pull cycle. Somewhat possible by hand when the bottom end is well anchored and the piston has something bolted onto it for grip. Non-gas shocks must be stood moreorless vertically for any test of function. |
Superhawk996 |
Nov 12 2021, 07:10 AM
914 Guru Group: Members Posts: 5,891 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
But I'm going to disagree slightly. The only thing you can test by any sort of hand test is verifying that there is oil in the damper. With hand forces, you're really only flowing oil though the piston bleed holes and not even deflecting the actual shim stack. If you had a shim stack, or base valve, that was broken in a catastrophic way (exceedingly rare), you could detect that too. If you want to see a suspension dyno in action and get a sense of the shaft velocities and forces involved in testing dampers properly: https://www.youtube.com/watch?v=UynHFv4cHyg |
Literati914 |
Nov 12 2021, 04:36 PM
Ok these are hydraulic I believe, so I’m thinking they’ll be fine. They came to me as ‘good’ inserts and nothing’s leaked out since they’ve been stored vertically. Thanks guys.
roblav1 |
Nov 12 2021, 09:13 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I'm sure they can wear out, but I used Konis on early 911/914 for decades and never had to replace any.
Lo-Fi Version | Time is now: 7th June 2024 - 06:25 AM |
