Reusing FASTEN SEAT BELT light?, connections for + and - ? |
FlacaProductions |
Nov 14 2021, 09:15 PM
Senior Member Group: Members Posts: 1,615 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Greetings,
On a 74 2.0 can the connector on the back of the FASTEN SEAT BELT light be disconnected without issue? I'd like to use that indicator for a different purpose as my interlock and associated wiring has already been bypassed.....just making sure it's not needed for continuity, etc. And if it CAN be disconnected, what are the basic + and - connections to illuminate it? |
JeffBowlsby |
Nov 14 2021, 11:23 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Greetings, On a 74 2.0 can the connector on the back of the FASTEN SEAT BELT light be disconnected without issue? I'd like to use that indicator for a different purpose as my interlock and associated wiring has already been bypassed.....just making sure it's not needed for continuity, etc. And if it CAN be disconnected, what are the basic + and - connections to illuminate it? The seatbelt light on a 74 only has two wires. A DVM is your friend. |
FlacaProductions |
Nov 14 2021, 11:47 PM
Perfect. I’ve been confused the use of different connectors over the years and I’m away from my 914 and doing some planning. Thanks.
Lo-Fi Version | Time is now: 6th June 2024 - 10:22 PM |
