hndyhrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 556 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() ![]() |
Does anyone sell the hose/tubing that goes from the windshield washer bottle across and into dash and then into steering assembly?
Is this something I can get local? If so any particular size, thickness etc. Thanks |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,403 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
Does anyone sell the hose/tubing that goes from the windshield washer bottle across and into dash and then into steering assembly? Is this something I can get local? If so any particular size, thickness etc. Thanks here is a thread on it mate. might help. http://www.914world.com/bbs2/index.php?sho...=354138&hl= think it might be mentioned in there for a USA source. |
hndyhrr |
Does anyone sell the hose/tubing that goes from the windshield washer bottle across and into dash and then into steering assembly? Is this something I can get local? If so any particular size, thickness etc. Thanks here is a thread on it mate. might help. http://www.914world.com/bbs2/index.php?sho...=354138&hl= think it might be mentioned in there for a USA source. Thank you |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
914rubber has a kit wit tubing etc, but your local FLAPS should have some that would work as well
PDXBob |
Newbie ![]() Group: Members Posts: 32 Joined: 16-May 20 From: Portland Oregon Member No.: 24,272 Region Association: Pacific Northwest ![]() ![]() |
I just replaced my rubber tubes for windshield washer. I got 4 mm (inside diameter) rubber tubing from local parts to work and doesn’t leak- so far.
PDXBob |
RiqueMar |
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California ![]() ![]() |
Agree with thew two-above. I originally got the 914rubber kit, but supplemented it with some material (same stuff) from a local autocrats store - all pretty straight-forward.
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Our kit also uses a heavier duty material. It's basically a mix of rubber and plastic. feels more like rubber, but can be thermally set. Meaning that you can heat it up and pish it onto the fittings and it will stay.
The kit is all the way from the stock at the steering column to the squinters https://914rubber.com/water-squirter-hose-kit-of-6-1 Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 11th June 2024 - 02:16 AM |
