ECU |
ECU |
jkb081 |
Nov 21 2021, 10:08 PM
Member Group: Members Posts: 78 Joined: 24-October 21 From: San Francisco, CA. Member No.: 26,018 Region Association: Northern California |
Looked through the forums, could not find anything on rebuilt or newer updated version of ECU for 914s. I see tips and advice for repairing or rebuilding everything else, except the ECU. Can someone direct me to the correct forum/thread that addresses this? My car: 73 1.7, thanks in advance!
rjames |
Nov 21 2021, 11:38 PM
I'm made of metal Group: Members Posts: 3,954 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Looked through the forums, could not find anything on rebuilt or newer updated version of ECU for 914s. I see tips and advice for repairing or rebuilding everything else, except the ECU. Can someone direct me to the correct forum/thread that addresses this? My car: 73 1.7, thanks in advance! No newer updated version. You're stuck buying used or rebuilt, or sending yours off to be rebuilt. Although last I heard, people weren't having much luck from at least one of the companies that used to rebuild them. I'd recommend posting a WTB ad here in the classifieds and then maybe ebay- would probably be a lot cheaper than buying a rebuilt unit from those who sell them. |
914Sixer |
Nov 22 2021, 09:31 AM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check with Jeff Bowlsby for rebuild or testing
dr914@autoatlanta.com |
Nov 22 2021, 10:08 AM
914 Guru Group: Members Posts: 7,893 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
funny thing is, that if a modern ECU was made it would be probably a one inch by one inch unit with a harness coming out of it to plut into the massive control unit harness plug. Someone could easliy make one like Dave Sprinkle, but the real reason for doing it would be to better manage the injection system, like a modern control unit could do
GregAmy |
Nov 22 2021, 10:33 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
funny thing is, that if a modern ECU was made it would be probably a one inch by one inch unit with a harness coming out of it to plut into the massive control unit harness plug. Someone could easliy make one like Dave Sprinkle, but the real reason for doing it would be to better manage the injection system, like a modern control unit could do You mean like putting a microsquirt ECU (about the size of a deck of cards) into a stock ECU case? Already been done. In my situation, I decided to swap the TPS, MAP sensor, and injectors with modern versions, and remove the disty and install a crank position sensor with external coil, all using stock 2L Djet plenum, runners, air cleaner assy. Works great... But you can probably make it work with the stock components, too. |
Lo-Fi Version | Time is now: 7th June 2024 - 01:13 AM |
