VDO Fuel Gauge Installation |
mmascari |
Dec 9 2021, 11:53 AM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Hello, looking for assistance installing a VDO fuel gauge. I am hoping someone has installed one and knows what wires connect to what terminals. Attached photo. There are two terminals and I assume these connect to the fuel sender. There is also a red/white/black set of wires. Any assistance would be great.
Attached image(s) |
mmascari |
Dec 9 2021, 12:07 PM
I also have this diagram that shows stock wiring to stock fuel gauge is
Ground(Brown) Green 2(Red/white stripe) Attached image(s) |
Luke M |
Dec 9 2021, 12:41 PM
Senior Member Group: Members Posts: 1,374 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
S = sensor
- = ground + = hot wire The other 2 posts look to be a light ? Flip the gauge over and take a pic. Are you sure that the gauge will work with your fuel tank sensor? I take this is a GT style fuel gauge? |
mmascari |
Dec 9 2021, 12:59 PM
S = sensor - = ground + = hot wire The other 2 posts look to be a light ? Flip the gauge over and take a pic. Are you sure that the gauge will work with your fuel tank sensor? I take this is a GT style fuel gauge? I can't confirm it will work. I assume it would. Attached image(s) |
mmascari |
Dec 9 2021, 03:15 PM
I found this doing a search, so maybe I need to get the correct gauge:
Posted from LarryM: here is the info from 2004 for correct gauge "here is the answer via VDO Support: Use VDO Part Number 301 020 with the OEM 914 fuel sender; (spec'd for Beetle O.E. sender or VDO 221012 sender): 73 - 10 Ohms, "Fuel" The reading will be off slightly but will not be noticeable William M. Reichart Technical Support Siemens VDO Automotive Corporation Service & Special Solutions Phone: 1-800-265-1818 Ext. 4018 |
914Sixer |
Dec 9 2021, 03:38 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
914 fuel gauge is 0-90 ohms.
mmascari |
Dec 9 2021, 04:36 PM
I was looking at the existing stock wiring to the fuel gauge and it shows
Ground Green 2 red/white stripe + What is the red/white stripe wire? I assume Green is from the sending unit |
GregAmy |
Dec 9 2021, 04:58 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Fuel gauge itself has two wires:
Red/White: keyed power Green: to the sender The black wire goes to the low fuel lamp Sender has three wires: Green: gauge Brown: ground Black: low fuel light inside the gauge |
mmascari |
Dec 9 2021, 05:02 PM
Fuel gauge itself has two wires: Red/White: keyed power Green: to the sender The black wire goes to the low fuel lamp Sender has three wires: Green: gauge Brown: ground Black: low fuel light inside the gauge Awesome, thanks. So, the Red/White would go to the + terminal on the gauge, the Green to the S on the gauge and the brown to the - on the gauge? |
Luke M |
Dec 9 2021, 05:37 PM
Fuel gauge itself has two wires: Red/White: keyed power Green: to the sender The black wire goes to the low fuel lamp Sender has three wires: Green: gauge Brown: ground Black: low fuel light inside the gauge Awesome, thanks. So, the Red/White would go to the + terminal on the gauge, the Green to the S on the gauge and the brown to the - on the gauge? Yup.. Like I posted earlier. What didn't believe me.. lol |
mmascari |
Dec 9 2021, 05:42 PM
Fuel gauge itself has two wires: Red/White: keyed power Green: to the sender The black wire goes to the low fuel lamp Sender has three wires: Green: gauge Brown: ground Black: low fuel light inside the gauge Awesome, thanks. So, the Red/White would go to the + terminal on the gauge, the Green to the S on the gauge and the brown to the - on the gauge? Yup.. Like I posted earlier. What didn't believe me.. lol Haha, thanks Luke! |
GregAmy |
Dec 10 2021, 09:13 AM
Lo-Fi Version | Time is now: 1st June 2024 - 07:57 PM |
