Injector and MPS connector pin removal, I have tools...which way though? |
FlacaProductions |
Dec 9 2021, 05:02 PM
Senior Member Group: Members Posts: 1,629 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Greetings,
Looking to replace the boots on my injectors and MPS connector and i have a somewhat large kit of pin removal tools thanks to Amazon but what does the one I need look like and does it enter from the connector side or the wire side? It's just hard to get in and get a good look to figure it out. Same question for the 4 pins on the MPS....thanks! |
914Mels |
Dec 9 2021, 08:09 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Greetings, Looking to replace the boots on my injectors and MPS connector and i have a somewhat large kit of pin removal tools thanks to Amazon but what does the one I need look like and does it enter from the connector side or the wire side? It's just hard to get in and get a good look to figure it out. Same question for the 4 pins on the MPS....thanks! You go in from the injector side, small flat blade. There is a fairly large tang to depress in the middle on the back side of the wire connector. I found replacement 2 wire connectors at Rock auto of all places about $4.50 each, cheap shipping also. |
FlacaProductions |
Dec 9 2021, 08:44 PM
Nice - thanks.
scott_in_nh |
Dec 10 2021, 08:11 AM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
I literally just did this two weeks ago with the same Amazon tool.
Use the biggest one that fits, I ended up using one side of a double pronged one - pretty much a trial and error until you find the one it likes... They were still being stubborn until I sprayed some lube down there and gave it a few minutes - that helped immensely. The Amazon tool is stamped from really thin gauge, so on some I had to slide one in, and then slide another on top to get the tang depressed enough (but maybe that stopped after I was lubing? I don't remember). Definitely a fiddly job if you are doing it under-hood - getting the connectors installed with the new boots is too! Scott |
FlacaProductions |
Dec 10 2021, 08:15 AM
Thanks, Scott.
Lo-Fi Version | Time is now: 17th June 2024 - 01:01 AM |
