Under engine tins |
Under engine tins |
jkb081 |
Dec 30 2021, 02:25 AM
Member Group: Members Posts: 78 Joined: 24-October 21 From: San Francisco, CA. Member No.: 26,018 Region Association: Northern California |
Sorry, keep getting “error” notifications
jkb081 |
Dec 30 2021, 02:30 AM
Sorry, keep getting “error” notifications I will try this one more time: My question was. Should my 73 1.7 have tins underneath the engine covering the push rod tubes. I have seen pictures of 914s with and without them. My air cooled VWs had them, even my water cooled Vanagon has them. So my question is, should my engine have them. I have searched online but cannot find an answer. |
DRPHIL914 |
Dec 30 2021, 06:40 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
@jkb081
Yes. there are the ones that are under(above) the push rod tubes and the one that is just above the shift rod, but all of those help deflect and direct air for cooling of the heads. Phil |
Mark Henry |
Dec 30 2021, 07:22 AM
@jkb081 Yes. there are the ones that are under(above) the push rod tubes and the one that is just above the shift rod, but all of those help deflect and direct air for cooling of the heads. Phil The ones that are under(above) the push rod tubes are a must have, the other lower tins only work with SSI or stock heat exchangers. |
jkb081 |
Dec 30 2021, 05:31 PM
@jkb081 Yes. there are the ones that are under(above) the push rod tubes and the one that is just above the shift rod, but all of those help deflect and direct air for cooling of the heads. Phil Thank you. Yes, my engine has those. I have seen pictures of engines on this site showing both with and without tins covering the bottom (side closest to the pavement) of the push rod tubes. I have also looked at several exploded views of engine tin placement pictures. However the print quality is very poor and hard to distinguish what is what. |
Lo-Fi Version | Time is now: 31st May 2024 - 09:09 PM |
