Flywheel!!! Help!!!, new one didn't come with locator studs |
djm914-6 |
Jul 23 2003, 06:41 PM
Happiness is: Getting on the road Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
So, we have this nice, new, shiny flywheel and it doesn't have locator studs. Do I have to remove from old flywheel? If so, how?
Lawrence |
Jul 23 2003, 06:59 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
I think the flywheel I installed didn't have locator studs.
The bolts on a 914/6 stock flywheel are in a specific pattern that allow you to put the flywheel on only one way. -Rusty (IMG:style_emoticons/default/smoke.gif) |
ejm |
Jul 23 2003, 07:01 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,694 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
You should be able to knock the dowel pins for the clutch out from the back using a punch. Tap them into the new flywheel with a bit of loctite.
Brad Roberts |
Jul 23 2003, 11:57 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Ed nailed it..
Tap them out and reuse the old ones. B |
BCinSC |
Jul 24 2003, 07:23 AM
Nothing but Trouble Group: Members Posts: 138 Joined: 8-June 03 From: Wakefield, MA Member No.: 800 Region Association: North East States |
Without them, what might happen? There are 6 bolts holding the thing in place.
djm914-6 |
Jul 24 2003, 07:41 AM
clutch won't be aligned or stay aligned
BCinSC |
Jul 24 2003, 09:11 AM
And you couldn't state that yesterday while I was mounting the pieces...
djm914-6 |
Jul 24 2003, 01:25 PM
"Tap them out" Easier said than done. Prior mechanic must have used superglue, cause these aren't budging. Have soaked in Liquid Wrench, heated to point of melting, sledge-hammered from behind and vise-gripped from front. These pins are pretty much toast. How can flywheel be shipped without? How can pins be NLA? AAAARRRRRRGGGGGGHHHHHH
MarkV |
Jul 24 2003, 01:51 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Buy new ones. I think they are just standard dowel pins that can be bought at any complete auto parts store. Don't go w/out them, they are essential.
Demick |
Jul 24 2003, 02:23 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
QUOTE(djm914-6 @ Jul 24 2003, 11:25 AM) "Tap them out" Easier said than done. Prior mechanic must have used superglue, cause these aren't budging. Have soaked in Liquid Wrench, heated to point of melting, sledge-hammered from behind and vise-gripped from front. Yep. That was my experience too. |
ejm |
Jul 24 2003, 08:05 PM
QUOTE(MarkV @ Jul 24 2003, 11:51 AM) Don't go w/out them, they are essential. I agree. The clutch can shift around on the bolts. The dowels insure precise alignment for balance purposes. They also keep inertia from shifting the clutch on the bolts eventually causing them to loosen. I have dowels I can bring up on Sat. if you can't locate them anywhere. |
Brad Roberts |
Jul 24 2003, 11:58 PM
I'm betting the dowels are metric.. and not something you can locate at Lowes.
I have several dowels I have collected over the years.. let me know if you need them. Snap On sells a special dowel pin puller that I have had to use in the past. B |
djm914-6 |
Jul 25 2003, 02:31 PM
Ed, If it's not too much trouble, please bring the dowels with you. Also, if possable, can you arrive on the early side? I'm hoping to get this car finished ASAP, maybe even in time for the ramble.
I can't imagine it'll take that much time to bolt the clutch back together, reinstall the tranny, torque the CV bolts and drop the car. How bad can it be? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/Yack.gif) |
ejm |
Jul 25 2003, 05:12 PM
Dave - Early is no problem, can be there by 10. Send me a PM if there's any other parts or tools I can bring.
Lo-Fi Version | Time is now: 8th June 2024 - 11:19 PM |
