Big time stupid V8 Q:, which hole do i stick the throttle cable |
Dr. Roger |
Jul 29 2005, 08:45 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
Inside the engine bay, just over where the clutch cable comes out, there is a big hole with a boot. That might be it or the one just next to it?
But most of these openings in the bulkhead go directly into my crank pulley. 'Geez, I hope it's an opening I just can't see.... V8 guys, Help! =-) (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) This post has been edited by rogergrubb: Jul 29 2005, 09:13 PM |
914GT |
Jul 29 2005, 09:22 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
It slides into a small tube sticking out of the firewall.
Dr. Roger |
Jul 29 2005, 09:40 PM
Hi Guy,
sorry for the stupid sounding question... I got this car without anything in the engine compartment. I don't know where anything goes, but i figured out the clutch no problem. Did you have the same problem with the throttle tube coming out right at the pulley? I'm going to bend it to point it straight up if that is what it takes..... ????? Without pinching it... |
914GT |
Jul 29 2005, 09:47 PM
Roger
This picture isn't the greatest but it shows the accelerator cable right above the speedo cable. I didn't need to bend anything to clear the balancer/pulley. Attached image(s) |
Dr. Roger |
Jul 29 2005, 09:59 PM
Hmmm,
either your pulley is much smaller than mine, or my engine is lower than yours. Pulley and engine mounts are from Renegade. I had to do the, "stick a small phillips into the tube and bend gently upwards" trick. Yea', there is definately something different between our two setups. ???? What, I have no idea. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) IT's all good now. |
914GT |
Jul 29 2005, 10:39 PM
You made it work that's all that matters.
neo914-6 |
Jul 29 2005, 11:04 PM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Someday we should take relative measurements of the DH, RS, Jaide, and RH engine support bar. Engine location in the bay is critical for several things.
I believe everyone mounts their w/p on the right side except RH. My throttle is a Terry cable Brad and crew routed straight back on the right side of the engine and up over. Not sure this is the best way since I could not get full motion to open the secondaries. Maybe a bell crank would help. Glad you worked it out Roger... |
Lo-Fi Version | Time is now: 10th June 2024 - 06:08 PM |
