| Shredhead |
Jan 28 2022, 10:30 AM
Member ![]() ![]() Group: Members Posts: 115 Joined: 10-August 15 From: CT Member No.: 19,047 Region Association: North East States |
I'd like to completely remove my fog lights, leaving just the wires, in preparation for painting and so I can clean them up on the bench. I'm not sure I see how the wires disconnect and would prefer not to cut them. Any tips?
Attached thumbnail(s) |
| 914Sixer |
Jan 28 2022, 10:40 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,356 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Using a little flat blade, unscrew set screw on bulb holder, be careful not to loose it. Pull out white/yellow wires (solder on ends). Slide off brown ground wire. Pull rubber plug out the housing.
| Shredhead |
Jan 28 2022, 02:09 PM
| 76-914 |
Jan 28 2022, 05:00 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,824 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
The tip of the + wire(s) is soldered but that soldered tip should be held in place by a set screw. Loosen it and it will slip out. Then just pull the spade connector off the ground terminal. Those wires look awfully new for a 50 YO car. Show us the other side of the bulb socket you are holding. Could be a PO did something a little differently when replacing those yellow/while wire(s). (IMG:style_emoticons/default/beerchug.gif)
| Shredhead |
Feb 5 2022, 01:22 PM
The tip of the + wire(s) is soldered but that soldered tip should be held in place by a set screw. Loosen it and it will slip out. Then just pull the spade connector off the ground terminal. Those wires look awfully new for a 50 YO car. Show us the other side of the bulb socket you are holding. Could be a PO did something a little differently when replacing those yellow/while wire(s). (IMG:style_emoticons/default/beerchug.gif) The set screw was right where you said it'd be and the wires popped right out. Without glasses, didn't notice it. (IMG:style_emoticons/default/smile.gif) Thanks for your help. |
Lo-Fi Version | Time is now: 7th December 2025 - 11:33 PM |
