QUOTE(914Sixer @ Jan 28 2022, 11:40 AM)
Using a little flat blade, unscrew set screw on bulb holder, be careful not to loose it. Pull out white/yellow wires (solder on ends). Slide off brown ground wire. Pull rubber plug out the housing.
So pull the wires out of their solders, right?
