| jagalyn |
Feb 5 2022, 11:48 AM
True Patina ![]() ![]() Group: Members Posts: 414 Joined: 31-January 06 From: Scandia, MN Member No.: 5,503 Region Association: None
I am looking for some period correct tires for my 74. Wondering if you have recommendations, experience or thoughts about which tire to buy.
There is an 'S' rated tire, a 'H' rated tire and a 'VR' rated tire. Because this car will be driven lightly and the fact that it is stored during winter months I wouldn't think the speed rating is really a factor. Also, which tread do you like for a period correct car? Any help would be appreciate. Thanks, Jeff ![]() |
| windforfun |
Feb 5 2022, 12:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
I am looking for some period correct tires for my 74. Wondering if you have recommendations, experience or thoughts about which tire to buy. There is an 'S' rated tire, a 'H' rated tire and a 'VR' rated tire. Because this car will be driven lightly and the fact that it is stored during winter months I wouldn't think the speed rating is really a factor. Also, which tread do you like for a period correct car? Any help would be appreciate. Thanks, Jeff ![]() Michelin XZX 165R15 |
| JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,236 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
I am going with the XZX when it comes time for my 74 2.0L. To me its the gold standard for our cars of that era.
| tygaboy |
Feb 5 2022, 12:21 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,805 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
I'm not a "period" guy but I am aware of the CN36, from back in the day. Possible choice?
https://www.longstonetyres.co.uk/pirelli-co...urato-cn36.html |
| Superhawk996 |
Feb 5 2022, 12:23 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,783 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
S speed rating (112 mph) will be fine.
Implies that it was run to SAE standard on a flat track machine in a lab for 1 hour, at rated load, at 100F lab temp without failure. So unless you're in AZ during the summer, driving high speed for extended durations you'll be fine. Example of the lab test machine used: https://www.youtube.com/watch?v=96ME_I5s-gQ |
| krazykonrad |
Feb 5 2022, 01:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,174 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
The Pirelli Cinturatos are what Porsche recommends. I think that they were OEM, but not for sure.
| fixer34 |
Feb 5 2022, 01:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,416 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
In the FWIW department, the COA on my '70 -6 listed Dunlop 165-15 as original equipment. That being said, it had 185/70-15 on when I bought it, and ever since.
| jagalyn |
Feb 5 2022, 01:42 PM
In the FWIW department, the COA on my '70 -6 listed Dunlop 165-15 as original equipment. That being said, it had 185/70-15 on when I bought it, and ever since. I have Dunlop's on my 74 15,000 mile car. They are original. But unfortunately period correct Dunlop's are not available. So, I'm trying to figure out the best option. |
| wonkipop |
Feb 5 2022, 03:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,480 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
i run XAS on my 74 1,8
no complaints. progressive. love the feel of the car with the old tall boy tyres. am back in 1989. no smashing on hard bumps and pot holes. light steering again. so far i have not got into trouble. i'm driving it reasonably hard on occasion but not stupid hard. but - no good in the rain. i don't drive the 14 in the rain anymore. eye popping expensive. (in aus ). the pirellis are more $. but closer to the original dunlop SPs the car once had. down here the 911 boys run the pirellis. seems to be the new groovy tyre of choice. if you can get your hands on a set. covid supply chain problems. the XAS are N code, same as pirelli. ie porsche recommend. if that means anything. personally i don't think its all that relevant to a stock 914 small 4. if you are driving the car lightly go for the vredestiens. they are a lot cheaper (at least here in aus). no point in handing out big $ for skinny michelins unless you are going to take corners at a little bit of speed and hold your breath. all 3 you have posted at top look period right on a 914. the michelins are period correct. don't think XAS were so common in the USA but very common on porsches at that time in aus. think dunlop SP were a real north american thing, something to do with being also a reasonable tyre in real winters. i believe the SP was originally developed as a rally tyre. it was also one of the first great tyres to be made in japan. thats where they came from. the japanese dunlop plant. |
| Van B |
Feb 5 2022, 04:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None
@wonkipop , you and I have talked about this before, but I’m going with 180 or 185 for my next set. The 165’s I have are too short and don’t give the right feel.
Hilariously to me, the spare in my car is the original and never used. It is Much taller and narrower at the tread. Additionally, getting the right diameter tire means my speedometer will be correct and I won’t continue to accrue phantom miles on the car. I think I’m sold on the XAS in 180 HR 15 after your experience and seeing they use softer rubber on the outside shoulders. I was looking at the vredestien in 185 VR 15, and still think it looks like a great tire, but tall boy Michey’s are just too cool to pass up! |
| wonkipop |
Feb 5 2022, 05:04 PM
@wonkipop , you and I have talked about this before, but I’m going with 180 or 185 for my next set. The 165’s I have are too short and don’t give the right feel. Hilariously to me, the spare in my car is the original and never used. It is Much taller and narrower at the tread. Additionally, getting the right diameter tire means my speedometer will be correct and I won’t continue to accrue phantom miles on the car. I think I’m sold on the XAS in 180 HR 15 after your recommendation and seeing they use softer rubber on the outside shoulders. I was looking at the vredestien in 185 VR 15, and still think it looks like a great tire, but tall boy Michey’s are just too cool to pass up! yeah van. i decided to scare myself and put the skinny skinny 165s on. (IMG:style_emoticons/default/evilgrin.gif) which is why i went XAS. the car when i first got it was running SP57s, but not the originals. (though the spare may have been original). i think it was a second set of dunlops on the car put on by original owner. i liked them. if i remember right they were loud though on the interstate in USA and highways here. not that it really mattered since i hardly ever drove with the top on. but i do remember they kind of "howled". if i went wider to 185s on more recent tyre shopping i'd have relaxed a bit on choice having a wider margin for "error". what i want to see is someone with enough nerve to run 155s (as period correct) on an early 4 with no roll bars. kill ya-self territory? but it would be period correct. man those things are skinny. (IMG:style_emoticons/default/blink.gif) PS - i think a wider vred would be fine in 185. a lot of the guys with old jags run them and they don't pussy foot around driving them either. so they are ok. just that it might be taking your life in your own hands at 165 wide. PPS - when i put the tyres on it was in the midst of the first covid lockdowns here. me and the old bloke who owns the classic tyre joint in town here had the shop to ourselves in a clandestine operation. he was in there charging up his tesla because he could not plug it in at home on his off grid farm. it was a very relaxed morning going right through his stock and talking it over. we had the car up on the hoist and he was admiring the suspension set up with roll bars etc and the new billies. asked me if it was stock. said, yep came out of the box that way except for the billsteins. and we discussed the engine. ie no power. "so its dangerous" was his summation. i said "yes". he said i really didn't have a choice at 165 and i would not be disappointed. |
| DBF |
Feb 5 2022, 05:30 PM
Member ![]() ![]() Group: Members Posts: 92 Joined: 29-August 21 From: Wisconsin Member No.: 25,865 Region Association: Upper MidWest |
I am also looking for period correct tires for the barn find BB I am putting back on the road. I am also thinking 165's. Let us know what you decide to do and how you like the tires. BTW - were Dunlap SP57 the original tires on a 74 714 2.0? I have that as my spare, and if it is original, I will leave it and pick up another rim for a spare. Thanks.
| wonkipop |
Feb 5 2022, 05:49 PM
another thing to mention with XAS.
they run "quiet". were developed for citroen. aside from grip etc, one of the requirements was silence. (at least by late 1960s measures). i hear the pirellis are noisy. not that it matters i guess. but if your the type who does not like cruising down the interstate listening to your tyres roar - something to bear in mind. these old school tyres are not like modern tyres in that department. we forget that. modern tyres have grip, rain performance etc, but an aspect that is not discussed often is that modern tyres are very quiet compared to old tyres. forget about rain performance with these tread patterns. puddles of standing water is not their strength. wet pavement is fine. but any thing else............. (IMG:style_emoticons/default/blink.gif) . |
| GeorgeRud |
Feb 5 2022, 07:43 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
195/65-15 is another possibility that will provide the correct sidewall height and a bit more width. Regardless hat you choose, they‘ll age out before they wear out.
| Cal |
Feb 5 2022, 07:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
| windforfun |
Feb 5 2022, 08:16 PM
Rip off. Is "tyre" even correct spelling? |
| horizontally-opposed |
Feb 5 2022, 08:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None
In the FWIW department, the COA on my '70 -6 listed Dunlop 165-15 as original equipment. That being said, it had 185/70-15 on when I bought it, and ever since. I have Dunlop's on my 74 15,000 mile car. They are original. But unfortunately period correct Dunlop's are not available. So, I'm trying to figure out the best option. Are the original tires on the original wheels, and not cracked on their sidewalls? If so, that's beyond cool and I'd be tempted to buy an extra set of wheels and mount 165R15 XZX or XAS if the car will only see light driving. Or, take the opportunity to try a set of 185/70R15 XWX. Or Pirelli CN36s. And of these will look "right" on the car and improve its performance too. |
| emerygt350 |
Feb 5 2022, 09:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,514 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
225/50r16. Choose your brand and tell your friends you would put the original pretzel tires on there but it just ain't safe.
| windforfun |
Feb 5 2022, 09:16 PM
225/50r16. Choose your brand and tell your friends you would put the original pretzel tires on there but it just ain't safe. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) I suppose you're from Rochester? (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) |
| wonkipop |
Feb 5 2022, 09:32 PM
225/50r16. Choose your brand and tell your friends you would put the original pretzel tires on there but it just ain't safe. i ran 195 goodrich T/As for a time on mine. worst tyre have ever had on a car. hated them. the car lost all its feather light steering feel. not to mention ride quality. the re run tyres from michelin are definitely a softer compound than back in the day. probably wear out in no time if it was a regular use daily driver. you got to be careful full stop in a stock 914 these days. the rest of the traffic can outbrake you. thats the biggest worry. esp if its wet or a bit greasy out there. but i don't have a horn machine chalon like you emery, making all the grannies go goey at the knees. (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 16th April 2026 - 10:05 PM |
