Installing stock combo gauge |
RustyWa |
Jul 31 2005, 12:37 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
I recently picked up a stock combo gauge, the one with fuel level and oil temp. I've already have a center console with the oil temp gauge installed there. I'm planning on using that space for something else.
My question. Do I need to run a new signal wire from the console location up to the new combo gauge for the oil temp? I've heard rumors that the wire is already behind the dash, but I can't seem to locate it. |
Dave_Darling |
Aug 1 2005, 11:29 AM
If you can't find the wire, just run a new one. Get a green one and dab some black paint on it so you know which wire it is; then a male spade connector and a female spade connector and you're set!
--DD |
RustyWa |
Aug 1 2005, 01:15 PM
That's what I eventually ended up doing Dave. I read a post long ago where you mentioned that the wire should be behind the dash, as well as the console, but I could not find it. It works of course. I was just looking for a nicer install.
Thanks for the reply. |
Aaron Cox |
Aug 1 2005, 01:22 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i used a femal spade connector and just extended the wiring from the console up to the combo gauge....
green wire... AA |
RustyWa |
Aug 1 2005, 01:42 PM
That's exactly what I ended up doing. What gauge did you end up putting in the console? |
Aaron Cox |
Aug 1 2005, 01:44 PM
i removed my console.... i have a 904 gauge (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 03:31 AM |
