| zoomCat |
Feb 12 2022, 12:24 PM
Member ![]() ![]() Group: Members Posts: 201 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None
There are different part numbers for the pressure regulators on the 4 and 6. Anybody know what the difference is?
| Superhawk996 |
Feb 12 2022, 01:44 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,125 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
The difference is in the set point at which the "regulator" begins to proportion rear brake pressure.
914/6 has a lower pressure knee point due to larger rear caliper pistons 38mm vs. smaller 33mm pistons for /4. ![]() I belive PMB can reset a /4 regulator to the /6 set point if need be. There are also two types (early & late) for /4's where the inlet and outlet ports changed location to accomodate different mounting locations between early and late. If you were going to try to obtain and use a /4 regulator for a /6, you would want the early version. |
| mlindner |
Feb 12 2022, 03:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
Wow Superhawk996 that is great info again. This is just the best Porsche forum ever. Mark
| partwerks |
Feb 12 2022, 07:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,642 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Is this that part that is mounted in the engine bay, about 1/2 way up towards the driver's side with the brake lines hooked to it?
| mepstein |
Feb 12 2022, 08:16 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,926 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
| zoomCat |
Feb 13 2022, 08:54 AM
The previous owner had changed out the pressure regulator for an adjustable proportioning valve, I'm going back to stock. Are there any visible differences between the two, or do I have to hunt down a /6 part to have Eric rebuild?
| mepstein |
Feb 13 2022, 09:12 AM
The previous owner had changed out the pressure regulator for an adjustable proportioning valve, I'm going back to stock. Are there any visible differences between the two, or do I have to hunt down a /6 part to have Eric rebuild? I don’t think there is a visible difference. I think it’s more of a setting on the part to achieve a different pressure release. I would think it’s a needle in a haystack to find the original six part. I would ask Eric directly but I bet he can achieve the exact same performance from an early 914-4 piece. Eric did write up a thread that dives into this part in detail. |
Lo-Fi Version | Time is now: 9th October 2026 - 11:20 PM |
