steering wheel shaking errrrr, errrr |
a.munoz3 |
Aug 1 2005, 12:18 AM
Member Group: Members Posts: 59 Joined: 16-June 04 From: Phoenix, AZ Member No.: 2,217 |
well............ ive had my 914 quite a while but havent had much time to mess around with but never hardly tooken it on the freeway. I decided why not hmm take it on the freeway and about 60 mph my steering wheel shakes and it shakes less if i speed up (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) ?? confusing do i need to have a balance job done?
Jeroen |
Aug 1 2005, 04:34 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
most likely, your wheels/tires need to be balanced
also check for play on the wheel bearings and balljoint |
ArtechnikA |
Aug 1 2005, 06:12 AM
and tie rods...
KevinP |
Aug 1 2005, 07:38 AM
Member Group: Members Posts: 205 Joined: 16-November 04 From: Orlando,FL Member No.: 3,127 |
Think I would check the brake rotors too....
Aaron Cox |
Aug 1 2005, 08:36 AM
check wheel balance...and get your car aligned.......
Joe Bob |
Aug 1 2005, 08:58 AM
Could be flat spotted tires as well.
tdgray |
Aug 1 2005, 09:09 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Have them check your grammer along with everything mentioned above (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Sorry just giving you (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif) |
TonyAKAVW |
Aug 1 2005, 09:18 AM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I had the same problem. Just got new tires mounted and balanced the other day and the problem is completely gone.
-Tony |
lapuwali |
Aug 1 2005, 10:47 AM
Try swapping your front tires to the back and see if the problem changes. If it's wheel balance or an out-of-round tire, there will still be vibration, but you'll feel it through your butt instead of through the steering wheel. If it doesn't change, it's a wheel bearing or a balljoint, most likely.
a.munoz3 |
Aug 1 2005, 01:19 PM
thx for the help
RustyWa |
Aug 1 2005, 01:30 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
When you get your wheels spin balanced, will the machine notice if your tire has a problem like a flat spot or a problem with a rim?
lapuwali |
Aug 1 2005, 01:47 PM
The tech should notice. You can see it wobble on the machine, and it will be hard to impossible to balance. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:31 AM |
