Sheridan article in Excellence, Not worth buying the mag |
Brett W |
Aug 1 2005, 09:28 AM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
I am not sure who this fellow was that wrote the article but it wasn't a very good article. He had some glaring mistakes. He says the "cage and structure to the front and rear shock towers is made of 1.0 and 1.25x.095 wall chromoly tubing, slightly larger than what the SCCA required". Wrong. SCCA won't allow anything smaller than 1 3/8 chromoly tubing.
All in all the article was not as good as the European Car article which it looks like this one was paraphrased from. |
URY914 |
Aug 1 2005, 07:35 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I caught the 1" tubing mistake also.
I thought the pictures sucked. Maybe Rodger didn't want anyone to see the front suspension details? P |
Brett W |
Aug 1 2005, 09:12 PM
His supension is not that complicated. He did what Kevin did to his car on a tube chassis scale. I am pretty sure that SCCA changed the rules to require the strut to be mounted inside the spring, so his setup is obsolete now. The rear is pretty trick but it is nothing that a good engineer or racer with good experience and knowledge couldn't come up with.
I have better pictures on my computer of Rogers car. IN addition to the set of articles from European car. |
Lo-Fi Version | Time is now: 10th June 2024 - 01:33 PM |
