Front trunk inner seal causing trunk to "bow", I know there's a thread on this, can't find it. |
Root_Werks |
Mar 17 2022, 03:27 PM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Front trunk aligns and closes with good gaps. Install the main outer seal, still good. Install the seal between fuel tank area and spare tire area and the trunk will bow.
I pulled the inner seal out for now. Used a scope camera and can see what looks like a pretty even 1/4" gap with inner seal removed. Use the camera again with inner seal installed and I can see the trunk rest down on the seal, but not compress it enough. It's a 914Rubber seal. Same front to back, rear trunk seal seems just fine. Any experience with this? Anyone? (IMG:style_emoticons/default/confused24.gif) |
Steve |
Mar 17 2022, 03:53 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Front trunk aligns and closes with good gaps. Install the main outer seal, still good. Install the seal between fuel tank area and spare tire area and the trunk will bow. I pulled the inner seal out for now. Used a scope camera and can see what looks like a pretty even 1/4" gap with inner seal removed. Use the camera again with inner seal installed and I can see the trunk rest down on the seal, but not compress it enough. It's a 914Rubber seal. Same front to back, rear trunk seal seems just fine. Any experience with this? Anyone? (IMG:style_emoticons/default/confused24.gif) It’s a known problem. The stock seal is lower and doesn’t cause the trunk lid to bow. |
sholman5 |
Mar 17 2022, 03:59 PM
Kraut burner Group: Members Posts: 189 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States |
Front trunk aligns and closes with good gaps. Install the main outer seal, still good. Install the seal between fuel tank area and spare tire area and the trunk will bow. I pulled the inner seal out for now. Used a scope camera and can see what looks like a pretty even 1/4" gap with inner seal removed. Use the camera again with inner seal installed and I can see the trunk rest down on the seal, but not compress it enough. It's a 914Rubber seal. Same front to back, rear trunk seal seems just fine. Any experience with this? Anyone? (IMG:style_emoticons/default/confused24.gif) I had the same problem. Pull the seal off and put the right side on the left and left on the right. Basically it is on backwards. Worked for me. |
914Mels |
Mar 17 2022, 05:03 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Front trunk aligns and closes with good gaps. Install the main outer seal, still good. Install the seal between fuel tank area and spare tire area and the trunk will bow. I pulled the inner seal out for now. Used a scope camera and can see what looks like a pretty even 1/4" gap with inner seal removed. Use the camera again with inner seal installed and I can see the trunk rest down on the seal, but not compress it enough. It's a 914Rubber seal. Same front to back, rear trunk seal seems just fine. Any experience with this? Anyone? (IMG:style_emoticons/default/confused24.gif) Noticed the front hood was sitting higher after putting in the new 914 rubber seal. Tried it both ways in the channel but it's too tall. put it in a couple months ago but it's not compressing. For now I just pulled it out, I might try to modify it but not sure short of cutting the flap part of what could be done. The front edge fits fine on the bumper. |
Root_Werks |
Mar 17 2022, 05:32 PM
Front trunk aligns and closes with good gaps. Install the main outer seal, still good. Install the seal between fuel tank area and spare tire area and the trunk will bow. I pulled the inner seal out for now. Used a scope camera and can see what looks like a pretty even 1/4" gap with inner seal removed. Use the camera again with inner seal installed and I can see the trunk rest down on the seal, but not compress it enough. It's a 914Rubber seal. Same front to back, rear trunk seal seems just fine. Any experience with this? Anyone? (IMG:style_emoticons/default/confused24.gif) Noticed the front hood was sitting higher after putting in the new 914 rubber seal. Tried it both ways in the channel but it's too tall. put it in a couple months ago but it's not compressing. For now I just pulled it out, I might try to modify it but not sure short of cutting the flap part of what could be done. The front edge fits fine on the bumper. Yup, same here, might wind up getting a universal seal that's softer and shorter or more shallow. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:08 PM |
