fitting new blinker relay |
63acornwall |
Mar 22 2022, 06:13 AM
Member Group: Members Posts: 53 Joined: 24-January 19 From: London , UK Member No.: 22,823 Region Association: None |
914Sixer |
Mar 22 2022, 06:20 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
What year car? Different locations. Seeing homemade modifications . Drop two middle phillips head screw and see what is back there.
Chris914n6 |
Mar 22 2022, 10:43 AM
Jackstands are my life. Group: Members Posts: 3,338 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
The two outer most screws release the panel. Then the black rectangle is the flasher relay. Seeing the new connectors... double check the wiring.
dhuckabay |
Mar 22 2022, 10:48 AM
Member Group: Members Posts: 224 Joined: 14-June 20 From: Idaho Member No.: 24,379 Region Association: Pacific Northwest |
63acornwall |
Mar 22 2022, 04:10 PM
Ok , took out the 2 outer screws and managed to drop panel a couple of inches . There were 2 relays , one had tags matching up with a replacement that I bought from a 911 shop . It was velcro’d onto the panel . I removed battery ground lead , swapped relays , reconnected battery , relay tested out fine . The hardest part was to get the panel back in , hard to see where screws were mounted while laying on back with head tucked under steering wheel - but done . Thanks for advice , not covered by Haynes manual !!
Lo-Fi Version | Time is now: 9th June 2024 - 12:03 PM |
