914-6 Turn Signal Switch Replacement?, Is there a 911 switch that will work? |
IronHillRestorations |
Apr 2 2022, 06:16 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I’m trying to find out if there’s a 911 turn signal switch that can be made to work in a 914-6.
The current project has a switch but the cancel mechanism is broken for one side. I was thinking that there was a 911 switch that would work with some easy modification. |
mepstein |
Apr 2 2022, 07:08 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The 911 switches will work but are usually big money. There are guys who repair and restore switches. Also big money but at least you know what you are getting. Check over at ESR for names of rebuilders.
914Sixer |
Apr 3 2022, 06:19 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check with Jeff Bowlsby, he made one from 911. Rich at HPH may have one.
mb911 |
Apr 3 2022, 07:24 AM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I use a 911 switch in my car and just soldered on the connector like a 914-6.
ClayPerrine |
Apr 3 2022, 07:28 AM
Life's been good to me so far..... Group: Admin Posts: 15,502 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The mid years 911 switch will work, but it won't look right in a real six. The shaft is different. The shaft on the early switches is a U shaped stamped steel part, the mid years are a steel rod. The early 911 switch is the same, but the electrical connector is different.
Apr 3 2022, 06:33 PM
@ClayPerrine so 69-73??
Biggles |
Apr 4 2022, 07:45 AM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
I’m trying to find out if there’s a 911 turn signal switch that can be made to work in a 914-6. The current project has a switch but the cancel mechanism is broken for one side. I was thinking that there was a 911 switch that would work with some easy modification. I had this problem not too long ago. Looked in Europe and US for.someone to fix the original switch. Only one person in US said he could do it. It was something like $1000. I ended up buying a NOS one from Freisinger Motorsport in Germany. It was £600. V expensive but they dont make 'em anymore ! |
dr914@autoatlanta.com |
Apr 4 2022, 08:30 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes we use a 68-73 and rewire the end for the factory 914-6 connector
I’m trying to find out if there’s a 911 turn signal switch that can be made to work in a 914-6. The current project has a switch but the cancel mechanism is broken for one side. I was thinking that there was a 911 switch that would work with some easy modification. |
Apr 4 2022, 08:41 AM
yes we use a 68-73 and rewire the end for the factory 914-6 connector I’m trying to find out if there’s a 911 turn signal switch that can be made to work in a 914-6. The current project has a switch but the cancel mechanism is broken for one side. I was thinking that there was a 911 switch that would work with some easy modification. Thanks George |
Lo-Fi Version | Time is now: 1st June 2024 - 02:37 PM |
