911 brakes on a 914, ATE Caliper ID is confusing |
Radio2115 |
Apr 3 2022, 04:30 PM
Newbie Group: Members Posts: 8 Joined: 12-November 20 From: Colorado Member No.: 24,879 Region Association: None |
My 914 has the larger 911 brakes. However I'm confused by what the caliper ID's may mean as they are all different on each wheel. The left rear is ATE 4, The right rear is ATE 10, the left front is ATE 284 while the right front is ATE 282. Is this correct or should the front caliper id's match each other as well as the rear? I'm going to need to replace pads at some point and would like to know if this setup is correct?
sixnotfour |
Apr 3 2022, 04:47 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
measure rotor width / thickness...easy indicator of what you have..
porschetub |
Apr 3 2022, 08:03 PM
Advanced Member Group: Members Posts: 4,705 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
measure rotor width / thickness...easy indicator of what you have.. (IMG:style_emoticons/default/agree.gif) solid rotor ,vented rotor ?? (there are 2 types I believe ) alloy or cast iron calipers ? do you have 911 rear handbrake setup ?,mine are 24mm 911 Carrera with 944T 4 piston calipers. A well sorted system stock will be fine even with upgraded engine to a point, my car was setup for 220hp but with my setup stops real good with a lot less power. Post some pics of your setup and you will get answers,cheers |
sixnotfour |
Apr 3 2022, 08:12 PM
oops
bdstone914 |
Apr 3 2022, 10:09 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
My 914 has the larger 911 brakes. However I'm confused by what the caliper ID's may mean as they are all different on each wheel. The left rear is ATE 4, The right rear is ATE 10, the left front is ATE 284 while the right front is ATE 282. Is this correct or should the front caliper id's match each other as well as the rear? I'm going to need to replace pads at some point and would like to know if this setup is correct? You are probably looking at cavity numbers. Most pictures of them or look on PMB website to natch to what you have. |
PatMc |
Apr 4 2022, 05:39 AM
Member Group: Members Posts: 120 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
You are probably looking at cavity numbers. Most pictures of them or look on PMB website to natch to what you have. This. Ate casting numbers are not useful in identifying what calipers you have...they simply refer to whatever tool pattern/core was used to cast them...more for production tracking than anything else. take some pictures of the front side and backsides of your calipers |
Shivers |
Apr 4 2022, 05:44 AM
Senior Member Group: Members Posts: 2,423 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Does sound like casting numbers, but the numbers could be different from side to side because you can have right and left caliper.
bdstone914 |
Apr 4 2022, 07:20 AM
Lo-Fi Version | Time is now: 8th June 2024 - 10:22 AM |
