QUOTE(sixnotfour @ Apr 4 2022, 11:47 AM)
measure rotor width / thickness...easy indicator of what you have..
solid rotor ,vented rotor ?? (there are 2 types I believe ) alloy or cast iron calipers ? do you have 911 rear handbrake setup ?,mine are 24mm 911 Carrera with 944T 4 piston calipers.
A well sorted system stock will be fine even with upgraded engine to a point, my car was setup for 220hp but with my setup stops real good with a lot less power.
Post some pics of your setup and you will get answers,cheers
