911 brakes on a 914, ATE Caliper ID is confusing |
Radio2115 |
Apr 3 2022, 04:30 PM
Newbie Group: Members Posts: 8 Joined: 12-November 20 From: Colorado Member No.: 24,879 Region Association: None |
My 914 has the larger 911 brakes. However I'm confused by what the caliper ID's may mean as they are all different on each wheel. The left rear is ATE 4, The right rear is ATE 10, the left front is ATE 284 while the right front is ATE 282. Is this correct or should the front caliper id's match each other as well as the rear? I'm going to need to replace pads at some point and would like to know if this setup is correct?
Lo-Fi Version | Time is now: 17th May 2024 - 09:14 PM |
