Definitive temp scale for console gauge, small-red-zone version |
FlacaProductions |
Apr 4 2022, 05:53 PM
Senior Member Group: Members Posts: 1,616 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Yes, there is a LOT of discussion here and I've read all of it I'm sure - most of it multiple times but is there a definitive temp scale for the small console gauge with the small red zone 914 641 118 30 and a 200c sender?
Does it match with the small-red-zone combo gauge 914 641 101 50? |
914Sixer |
Apr 5 2022, 06:23 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
There same factory sender works with both gauges. My understanding is there is different resistance in each gauge.
GregAmy |
Apr 5 2022, 07:11 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Superhawk996 |
Apr 5 2022, 07:57 AM
914 Guru Group: Members Posts: 5,898 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Can anything without a printed scale be considered definitive?
FlacaProductions |
Apr 5 2022, 09:14 AM
That's what I'm looking for @Superhawk996 - to put numbers on that numberless scale.
Superhawk996 |
Apr 5 2022, 09:25 AM
Setting aside the question of why, you have the numbers for the center console gauges and as you can see, the calibration of the gauge is dependent on what temp sensor is used. I have not seen a similar calibration for the combination gauge and/or the 914/6 gauge. In the same manner as the center gauges, the calibration of the scale would be dependent on what temperature sensor is used. As we all know by know, there are lots of gauges out there with the wrong sender. So maybe still not definitive unless you calibrate your gauge to your sender. Would be easy enough to do. Hook up gauge and sensor on bench, submerse the sensing portion of the sender in oil, heat up the oil and note positions at each desired temperature increment of the oil using a IR temp gun, candy thermometer, or Thermocouple. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:18 PM |
