WTB inspection plug bell housing side and throttle return spring (FOUND) |
L-Jet914 |
Apr 10 2022, 12:24 AM
Member Group: Members Posts: 253 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I know the bell housing plug is probably a long shot, but after learning that mine had gone missing over the years I would like to replace it. I am also in search of the throttle return spring that goes from the throttle body to the rear engine tin by the rear trunk fire wall. I might also check out the local ACE Hardware for one as well. The one that is in my 74 1.8, I found out is the wrong type spring and currently installed in the wrong area (currently attached to the intake plenum attachment point). Part numbers 022 129 881 F (100mm) PET# 2 MG 1: Engine, and 021 101 109 A PET# (36) MG 1:Engine
Attached image(s) |
KevinW |
Apr 10 2022, 09:57 AM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
I may have one. I’ll check when I get back home this afternoon.
KevinW |
Apr 10 2022, 06:27 PM
I have the inspection plug and a few springs. If someone knows the correct length of the spring.
I may have one. I’ll check when I get back home this afternoon. Attached thumbnail(s) |
L-Jet914 |
Apr 10 2022, 06:52 PM
PM sent.
L-Jet914 |
Apr 10 2022, 07:27 PM
Parts found and funds sent. Thread closed.
Lo-Fi Version | Time is now: 8th June 2024 - 03:03 PM |
