L-Jet914
Apr 10 2022, 12:24 AM
I know the bell housing plug is probably a long shot, but after learning that mine had gone missing over the years I would like to replace it. I am also in search of the throttle return spring that goes from the throttle body to the rear engine tin by the rear trunk fire wall. I might also check out the local ACE Hardware for one as well. The one that is in my 74 1.8, I found out is the wrong type spring and currently installed in the wrong area (currently attached to the intake plenum attachment point). Part numbers 022 129 881 F (100mm) PET# 2 MG 1: Engine, and 021 101 109 A PET# (36) MG 1:Engine
KevinW
Apr 10 2022, 09:57 AM
I may have one. I’ll check when I get back home this afternoon.
KevinW
Apr 10 2022, 06:27 PM
I have the inspection plug and a few springs. If someone knows the correct length of the spring.
QUOTE(KevinW @ Apr 10 2022, 07:57 AM)
L-Jet914
Apr 10 2022, 07:27 PM
Parts found and funds sent. Thread closed.
