WTB inspection plug bell housing side and throttle return spring (FOUND) |
L-Jet914 |
Apr 10 2022, 12:24 AM
Member Group: Members Posts: 237 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I know the bell housing plug is probably a long shot, but after learning that mine had gone missing over the years I would like to replace it. I am also in search of the throttle return spring that goes from the throttle body to the rear engine tin by the rear trunk fire wall. I might also check out the local ACE Hardware for one as well. The one that is in my 74 1.8, I found out is the wrong type spring and currently installed in the wrong area (currently attached to the intake plenum attachment point). Part numbers 022 129 881 F (100mm) PET# 2 MG 1: Engine, and 021 101 109 A PET# (36) MG 1:Engine
Lo-Fi Version | Time is now: 18th May 2024 - 03:04 AM |
