Driving lights stopped working... |
advman89 |
Apr 20 2022, 07:45 AM
Member Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest |
My big winter project--dash rebuild was going great. Been very careful with the wiring over the last couple months.
I had everything in place, but once I got the switches back in, my driving lights are not coming on. The dash switch lights up. Headlights are operational. I quickly checked for any loose connections, but didn't see anything. I have checked all the fuses (I have the updated blade fuse panel). Any places to start? sooooooo close.... |
barefoot |
Apr 20 2022, 12:57 PM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
First thing, check to see if you've got voltage at the lights, If you can't pull a connector apart, just stick a pin into the insulation to contact the wire within using a multi-meter.
If nothing there go back to fuze panel. |
advman89 |
Apr 20 2022, 01:00 PM
thank you....I don't see them listed on the fuse diagram or or the cover...any clue which fuse it is?
DRPHIL914 |
Apr 20 2022, 01:16 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
thank you....I don't see them listed on the fuse diagram or or the cover...any clue which fuse it is? this has happened to me a couple times, one time it was loss of ground connection at the fog/driver lights, one has been a slightly loose connection on the switch, and other was a bad light switch. |
dr914@autoatlanta.com |
Apr 20 2022, 01:33 PM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
fuse connection, car set on low beam with the key on, driving light ground, fuse block black round relay
My big winter project--dash rebuild was going great. Been very careful with the wiring over the last couple months. I had everything in place, but once I got the switches back in, my driving lights are not coming on. The dash switch lights up. Headlights are operational. I quickly checked for any loose connections, but didn't see anything. I have checked all the fuses (I have the updated blade fuse panel). Any places to start? sooooooo close.... |
advman89 |
Apr 20 2022, 07:57 PM
HIGH BEAMS it was. I knew it had to be some simple...
Thank you Dr. ! |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:18 PM |
