Side shifter seal, Leaker |
r_towle |
Apr 24 2022, 11:56 AM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Car leaks….surprise
I’m seeing a fresh drip of oil coming off the bottom of the shifter console, side shifter Must I remove the console to find and fix this, or can I replace a seal from outside? I remember the o-ring that seals the shifter console itself, but I have no memory of a seal at the shifter rod itself. This is a resurrection of a car that has sat for 20 years. I already have a box of rubber from 914rubber to do all the oil seals, pushrod seals, fuel lines etc. Seems the tranny might be leaking instead…. Rich |
Dave_Darling |
Apr 24 2022, 01:15 PM
You must remove the console to fix it.
There is an O-ring that goes around the outside of where the console goes through the case. There are also seals between the shift selector rod and the console. Though if the latter fail, you tend to fill up the plastic cover before it starts to drip. --DD |
Superhawk996 |
Apr 24 2022, 03:13 PM
914 Guru Group: Members Posts: 5,899 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Though if the latter fail, you tend to fill up the plastic cover before it starts to drip. --DD Been there, done that. School of hard knocks. Pre-internet era. Went to remove cover to adjust linkage cone screw. Poured that stank soup of gear oil and water all over myself. (IMG:style_emoticons/default/hissyfit.gif) |
r_towle |
Apr 24 2022, 04:29 PM
You must remove the console to fix it. There is an O-ring that goes around the outside of where the console goes through the case. There are also seals between the shift selector rod and the console. Though if the latter fail, you tend to fill up the plastic cover before it starts to drip. --DD Thankfully the cover is off, or tipped open. Seals between shift selector? Are these press in or easy to do? I bet the thing is empty, but I will be ready for whatever is left. Yeehah |
Chaznaster |
Apr 24 2022, 04:37 PM
Member Group: Members Posts: 305 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
You must remove the console to fix it. There is an O-ring that goes around the outside of where the console goes through the case. There are also seals between the shift selector rod and the console. Though if the latter fail, you tend to fill up the plastic cover before it starts to drip. --DD (IMG:style_emoticons/default/agree.gif) Remove and replace with new rings/ seals is a pretty easy job. In fact, for me, easier than expected/ |
r_towle |
Apr 24 2022, 06:42 PM
As always, thank you!
Gotta go put another order together for more seals |
anderssj |
Apr 25 2022, 08:24 PM
Dog is my copilot... Group: Members Posts: 1,663 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
You must remove the console to fix it. There is an O-ring that goes around the outside of where the console goes through the case. There are also seals between the shift selector rod and the console. Though if the latter fail, you tend to fill up the plastic cover before it starts to drip. --DD (IMG:style_emoticons/default/agree.gif) Remove and replace with new rings/ seals is a pretty easy job. In fact, for me, easier than expected/ (IMG:style_emoticons/default/agree.gif) x2 I was pleasantly surprised at how easy this was. Good time to check/replace any worn bushings and etc. |
dcecc1968 |
Apr 26 2022, 02:04 PM
Member Group: Members Posts: 252 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
Hmmm… I recently replaced my shift rod cone screw and noticed a little gear oil in the plastic cover. Anyone have a photo of the console that needs to be removed? Is that simply the shaft?
Dave_Darling |
Apr 26 2022, 03:47 PM
The "console" is the piece that holds the castle bushing, and the gear selector shaft, and the cover. It is held onto the bottom/side of the gearbox housing with two nuts (M8/13mm wrench if I recall correctly).
The gear selector shaft has a rake on one side and a ball stud on the other, both held on by roll pins. Drive out one roll pin, take the piece on that side of the console off, slide the shaft out the other side, and then pry out the old bushings/seals and install new ones. (This assumes you have already removed the console and dumped all your gear oil out.) --DD |
r_towle |
Apr 26 2022, 03:54 PM
Make sure car is in neutral before removing shifter console.
When re-installing, make sure all the notches in the tranny shifter rods line up , which shows you are in neutral. Redbeard wrote a good article on this at Pelican. There is also a good thread with pictures on Pelican, again redbeard commenting. All of that is circa 2010 ish |
dcecc1968 |
Apr 27 2022, 04:38 AM
Thanks fellas!
Lo-Fi Version | Time is now: 9th June 2024 - 08:31 AM |
