Phenolic Spacers, Gaskets, Carburetors & Such |
Craigers17 |
Apr 30 2022, 05:28 AM
Senior Member Group: Members Posts: 740 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
I am looking for some advice on carburetor setup. I know there are 100's of threads on this, but I am looking specifically for advice on setup for IDF 40's. I've read where putting phenolic spacers in place limit the possibility of boiling the gas.
So my first question is what is the basic setup? Are we talking about a Victor Reinz type of gray/black gasket between the head and the manifold intake. Then a 1/4 or 1/2" phenolic spacer between the intake and the carburetor? Also, is there a paper/cork gasket that has to go on either side of the phenolic spacer? I plan on replacing the hex bar with either the CSP linkage or, more than likely, Chris's pulley setup, but I want to make sure the setup between the carbs and manifolds is ideal before I start tinkering with the air flow and syncing them. Any feedback would be great. Here is a pic of the spacers that I'm looking at: |
mb911 |
Apr 30 2022, 06:36 AM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
On a 911 based engine it goes gaskets, phenolic, gasket, intake, gasket, carb.
Is that what you were looking for? |
Craigers17 |
Apr 30 2022, 07:06 AM
On a 911 based engine it goes gaskets, phenolic, gasket, intake, gasket, carb. Is that what you were looking for? @mb911 Yes thanks! However, when I was researching this topic, I also found the following pic. Is this unnecessary, overkill, or just dependent on engine size/configuration? Notice the spacers between the carbs and intakes. |
rhodyguy |
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Those spacers pictured live between the the intakes and the carbs. I have a set. The ones between the heads and intakes are the simply the stock FI ones. 3 or 4 stud holes dependent on the heads. Designed to help with bowls/fuel heat soak while the car sits after a drive. Picture beat me to the usage.
brant |
Apr 30 2022, 07:17 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Also
You will likely need longer studs to accommodate the spacers Use care pulling the stock studs out of the heads |
rhodyguy |
Apr 30 2022, 07:27 AM
Stock intake studs work with the CB talls. Shorty intakes with a thick boss on the bottom flange? One intake stud is too short. Stick with the talls. The Belleville/Schnor washers for exhaust studs work much better than cut washers on the intake studs.
Craigers17 |
May 1 2022, 03:34 AM
Thanks for everyone's input. This is the information I needed. I appreciate it!
Ansbacher |
May 1 2022, 09:33 AM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
I have tried phenolic spacers on several carb setups on my 914 and my former 356SC and they never took care of fuel boil off during Florida summer driving. I see you are in Georgia where it gets pretty hot too. Not sure how effective they will be for you. Worth a try, I guess. Good luck.
Ansbacher |
brant |
May 1 2022, 09:51 AM
I have tried phenolic spacers on several carb setups on my 914 and my former 356SC and they never took care of fuel boil off during Florida summer driving. I see you are in Georgia where it gets pretty hot too. Not sure how effective they will be for you. Worth a try, I guess. Good luck. Ansbacher Did you run a return fuel line in your cars? |
Lo-Fi Version | Time is now: 1st June 2024 - 08:57 PM |
