| Literati914 |
May 4 2022, 12:30 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,268 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
My ‘72 has two small holes, at the front part of the passenger’s side floor… they look factory and are approx 3/8” or so & spaced approx 8-9” apart.
I can not figure out what these are for and was hoping someone could shed light on it, before I weld them shut - and end up wishing I hadn’t. . |
| Literati914 |
May 4 2022, 02:58 PM
Could these two holes be related to an A/C install? They’re on the floor as mentioned but (IMG:style_emoticons/default/confused24.gif)
| ClayPerrine |
May 4 2022, 03:18 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
| Shivers |
May 4 2022, 03:25 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,348 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I went out and looked at my 72', it still has the sound material, but I saw nothing bolted to the floor inside or out.
| Literati914 |
May 4 2022, 03:32 PM
I went out and unloaded the right side of my other ‘72 (using it to store parts for the moment)… and it too has these holes and they are plugged with a small rubber ..plug. The plugs are flat on the interior side and a wide short point on the outside. I’m sure My original plugs are gone now.. I’ll double check, but I may need a couple. Here’s a pic:
Attached thumbnail(s) |
| markhoward |
May 4 2022, 04:02 PM
Member ![]() ![]() Group: Members Posts: 403 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California
| Root_Werks |
May 5 2022, 09:43 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,940 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
My 75 doesn't have them, maybe for the foot rest on early cars?
| jrmdir |
May 5 2022, 09:51 AM
Member ![]() ![]() Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest
Early cars with fixed passenger seats had adjustable foot rests, didn't they?
I've never seen one, but were they bolted to the floor? Perhaps the stamping tooling was not changed until later? EDIT: Sorry Root Werks, I didn't see your prior similar suggestion. Ron |
| Cairo94507 |
May 5 2022, 09:56 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,611 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
No adjustable footrest I have ever seen in any 914 unless you are talking about the "dog bone" that just sat on the floor for the passenger to use if they chose. (IMG:style_emoticons/default/beerchug.gif)
| doug_b_928 |
May 5 2022, 10:02 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 730 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
For some additional info see here: http://www.914world.com/bbs2/index.php?sho...holes&st=20
I recently asked Mark about these and he indicated he is looking into making the correct plugs (as well as the plus for the frunk). @mikey914 |
| Mikey914 |
May 5 2022, 01:36 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,775 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Yes, I've checked 3 of my cars so far and can't find a decent one yet. I have a few at another location I can check, so still in progress. Once I have it will be a inexpensive part.
Mark |
| johnhora |
May 5 2022, 02:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 902 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None
Checked my 70' 914-6 and it has these two holes also. Never really noticed them before.
The early foot rest/dog bone was kept from moving too far by a strap that had a clip that snapped into a D-ring that was attached via the speaker cover bottom screw. I wonder if it's for the Webasto heater exhaust pipe....I had an early 911 with the gas heater and it had a small muffler and exhaust pipe that was bolted to the bottom of the floor board on the passenger side.... From a few pictures it looks like the 914 webasto heater was placed on the driver side in the front trunk but maybe the exhaust went to the passenger side...does anyone have the 914 webasto heater installed. |
| SirAndy |
May 5 2022, 05:50 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,473 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I wonder if it's for the Webasto heater exhaust pipe....I had an early 911 with the gas heater and it had a small muffler and exhaust pipe that was bolted to the bottom of the floor board on the passenger side.... From a few pictures it looks like the 914 webasto heater was placed on the driver side in the front trunk but maybe the exhaust went to the passenger side...does anyone have the 914 webasto heater installed. @johnhora The webasto heater was installed in the front trunk and had to have a larger exhaust hole added manually. http://www.914world.com/bbs2/index.php?showtopic=8825 (IMG:style_emoticons/default/bye1.gif) |
| Garland |
May 15 2022, 09:18 AM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
| wonkipop |
May 15 2022, 04:12 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,480 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
99% think it would be for AC.
DPD version. jeff bowlsby website. pdf of installation instructions for system if you are interested enough. seems to show one of those holes in lhs location. instructs for a second hole in firewall but with instruction to take care to avoid fuel tank overflow drain tube. my guess is that installers modified the installation to include second hole in floor and ran the hose in that way to avoid the issue? https://bowlsby.net/914/Classic/zTN_Man10.pdf could be confirmed by looking for other evidence of an ac install at some point in time. |
Lo-Fi Version | Time is now: 15th April 2026 - 07:27 AM |
