Recommendations for Tying Short Rear Springs? |
bkrantz |
May 8 2022, 09:03 PM
914 Guru Group: Members Posts: 7,791 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
With my most recent ride height adjustment my rear springs are too short for the perch positions. Any recommended methods for tying the springs to upper and/or lower perches?
r_towle |
May 8 2022, 09:45 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Do you mean the springs are too short when you jack up the car?
If yes, drill three holes in the top, fixed position perch, and zip tie the spring , properly aligned, to the top perch to prevent it from rotating on the upper perch, and as you put the car back on the ground, make sure tge lower perches align properly |
Mark Henry |
May 9 2022, 05:12 AM
If you have the new style Bilsteins you can drill and zip-tie the top and bottom perches, the lower perch will ride up the shock when you lift the car. The older style you can't zip-tie to lower perches and have to clock the springs as above.
BTW if your springs are too short you have aftermarket progressive springs, I think 150lbs was the most common, but they come in several ratings. |
Superhawk996 |
May 9 2022, 05:24 AM
914 Guru Group: Members Posts: 5,876 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Helper spring.
Mark Henry |
May 9 2022, 05:36 AM
Superhawk996 |
May 9 2022, 06:30 AM
Mark,
You've got me thinking my response wasn't well thought out. I just went and looked at my Bilstein rears. I think the main issue is the 914 spring is an open end spring. Helpers are largely designed for use with coil overs with springs that have a flat, closed & ground end form. I don't think helpers will sit properly in the spring perches. |
white1975 |
May 9 2022, 08:17 AM
Member Group: Members Posts: 94 Joined: 28-December 10 From: Milford ohio Member No.: 12,529 Region Association: None |
i have ritchie ginther 180 lb springs safety wired to bottom and top 80s Billsteins
bkrantz |
May 9 2022, 08:12 PM
Thanks, guys. I went with my springs wired only to the upper perch for now. The lower perch is close enough to locate the spring end.
Attached thumbnail(s) |
Mark Henry |
May 10 2022, 11:13 AM
That's the newer perch style that will ride up the shock tube if you zip-tie the perches top and bottom (progressive springs).
As the spring works it actually twists as it goes up and down, slowly spinning the spring. A big bump or jacking the car up and the lower perch can get spun off of it's index with progressives, so I do recommend drilling and zip-tie (or safety wire) the bottom perch on this style of perch. BTW the stock style spring doesn't have this issue (IMO) as it's always sprung. |
CHIZ 914 |
May 10 2022, 11:53 AM
Member Group: Members Posts: 200 Joined: 14-May 18 From: Mountlake Terrace, Wa Member No.: 22,118 Region Association: None |
bkrantz |
May 10 2022, 08:20 PM
^Nice. But teasing. I had a similar set up on my 914 race car.
r_towle |
May 10 2022, 08:51 PM
Lo-Fi Version | Time is now: 1st June 2024 - 05:44 PM |
