How to inspect the suspension console, looking for a "how to" |
seanpaulmc |
May 10 2022, 06:18 PM
Member Group: Members Posts: 304 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
Greetings -
Has anyone outlined a procedure for inspection of the suspension console – Passenger side? If you’ve seen any of my other posts, then you’ll know my teener is not short on rust repair needs. I have little history of the car and only drove it a few miles before determining the rust was bad enough driving it did not warrant my risk. I am working my way through the metal repairs. I understand one of the failures that tends to come with a lot of passenger side hell hole rust is the failed suspension console. I am looking for a method on how to test / inspect it while I have the drivetrain out and the car on jack stands. As always, I appreciate your help and support! Sean |
914werke |
May 10 2022, 08:14 PM
"I got blisters on me fingers" Group: Members Posts: 10,141 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Take a pick, screwdriver, whatever & start stabbing.
Your looking for soft metal. |
r_towle |
May 10 2022, 08:56 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
It starts with a beer
Typically three beers is perfect for rust inspection Using a rustometer, which is similar in shape to an ice pick or a screw driver, poke at the area to get inspected. Once you think the rustometer has detected rust, your 4th beer may be in order . It is also advised to do your inspection with close friends that can help you cope with your findings. |
porschetub |
May 11 2022, 10:43 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
It starts with a beer Typically three beers is perfect for rust inspection Using a rustometer, which is similar in shape to an ice pick or a screw driver, poke at the area to get inspected. Once you think the rustometer has detected rust, your 4th beer may be in order . It is also advised to do your inspection with close friends that can help you cope with your findings. So true (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 07:12 PM |
