> Legal to make "holes" in roll bar for PCA or SCCA?, picture of intended mod:
Mueller
post Aug 2 2005, 07:06 PM
914 Freak!
Had a full cage on my last car done by Tony at TC Design , with my new car, I just want a roll bar as outlined in the red...however, I'd like to have a removable petty bar(to be installed at the auto-x course or track)
what I am trying to figure out is whether or not it's acceptable to drill thru holes and weld in strenghtening tubes into the rollbar for the hardware to pass thru.
Replies(1 - 16)
Mueller
914 Freak!
opps...forgot the outline picture....
URY914
post Aug 2 2005, 07:44 PM
I had holes like that in my main hoop and made it thru a PCA tech inspection.
Depends on how close they look.
P
Mueller
post Aug 2 2005, 08:05 PM
914 Freak!
the petty bar would mount with something similar to this...
Howard
post Aug 2 2005, 08:17 PM
Incontin(g)ent Member
OK in POC. But mine had larger diam sleeves at the 'joints'. Bolted thru both.
Mueller
post Aug 2 2005, 08:21 PM
914 Freak!
QUOTE (Howard @ Aug 2 2005, 07:17 PM)
so the "sleeves" just stayed on when the bar was removed?
Howard
post Aug 2 2005, 08:29 PM
No, wish I had a better picture (took cage out). Sawed thru the main bar. Cut larger diam sleeve. Drilled both. Bolted back together.
Then unbolt, remove center section and sleeves. Stub was covered with foam for street use.
ChrisFoley
post Aug 2 2005, 09:35 PM
I am Tangerine Racing
If you do it such that there is no perceived weakness there should be no problem. Your idea of welded in sleeves for the bolts to pass through looks fine to me.
The GCR has pictures of a couple of acceptable methods of bolt together joints. I think you can access the GCR online at SCCAdotcom.
MattR
post Aug 2 2005, 09:54 PM
Why not weld on a bracket?
Mueller
post Aug 3 2005, 12:07 AM
914 Freak!
QUOTE (MattR @ Aug 2 2005, 08:54 PM)
I could, I want to avoid the "normal" type of bracket which protrudes into the cabin. Ideally you want the axis of the petty bar to line up with the centerline of the mating tube.
I'm betting that just about any design (as long as it's safe and strong) will be sufficient and better than not having anything at all....I was just fishing to see if anyone had done something "different" (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
mikerose
post Aug 3 2005, 08:06 AM
Happy to be back
Hi Mike like this
(IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
mikerose
post Aug 3 2005, 08:08 AM
Happy to be back
More
mikerose
post Aug 3 2005, 08:09 AM
Happy to be back
mikerose
post Aug 3 2005, 08:11 AM
Happy to be back
Brett W
post Aug 3 2005, 09:06 AM
You can make the holes as long as you make a bushing that you can weld into the tube. Check out how this car was done:
Brett W
post Aug 3 2005, 09:08 AM
damn forgot to add the pic.
Terrance
post Aug 3 2005, 07:10 PM
Mike, you can do it as stated somewhere above. Just need a "bushing". I think it's the recomended way to do it anyways.
I might have a pic somewhere
- Lo-Fi Version Time is now: 15th April 2026 - 07:27 AM
