| ctc911ctc |
May 18 2022, 10:38 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,327 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
'74 2.0 - mostly original
I am in the middle of rebuilding of the front end - all new bushings, shocks, etc. Torsion Rods are in very good shape though they are both marked "R".... I was told on this board that an R can be inserted in reverse which would make it an L, is this OK......??? I am trying to replace the cotton washer that seems to hold the grease in the torsion rod container. I have found some made of a spongy synthetic material instead of the cotton found in original cars. I am thinking about replacing the original cotton washers since they seem OK, Should these be replaced? How critical do we think this component is ? See #22 ![]() |
| Root_Werks |
May 18 2022, 10:54 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,947 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
If it was me, if they are in good shape, resuse them. No sense replacing something if it has another 10+ years of service left.
| mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,634 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I think the cotton washer is just to help hold grease in and dirt out. I believe it’s fine to reuse them. At the shop, the guys would cut some out of foam rather than take the time to get one or pay the Porsche price for a new one.
| Olympic 914 |
May 18 2022, 10:55 AM
![]() ![]() ![]() Group: Members Posts: 1,772 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
Probably good to have something in there, just to keep the dirt out.
I cut a slice of pool noodle foam and put That in there. Mark beat me to it. |
| Retroracer |
May 18 2022, 10:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 655 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest
ditto on the DIY foam fix...
- Tony |
| ctc911ctc |
May 18 2022, 11:02 AM
We are in agreement - will wash and dry the cotton and reuse.
Thank you Teeners! |
| Shivers |
May 18 2022, 11:03 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,348 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Or a piece of wool felt from a craft store. Comes in different thicknesses.
| dr914@autoatlanta.com |
May 18 2022, 12:27 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,233 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
and of course they are still available new
| Dave_Darling |
May 18 2022, 11:21 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Note that if you swap a torsion bar end-for-end it is still loaded in the same direction. (If you doubt that, try marking a paper towel tube or something similar.)
What I have read (in Panorama years ago) is that the torsion bars were actually all the same. They were marked for installation so that they could be installed back in the same side they came out of, because reversing the stress tended to lead to premature failure. If you can't tell which side they came out of, just re-install and hope. You have a 50-50 chance of getting it right, and even if you don't it may last for a while anyway. --DD |
| ctc911ctc |
May 20 2022, 02:16 PM
George,
You may have noticed I went to your site first, they stated OEM but the picture was of the porous synthetic foam - which started the discussion. Buy lots of stuff from you - thank you! May still get these from you, and of course they are still available new |
| ctc911ctc |
May 20 2022, 02:17 PM
Dave - good solid logical advise, Seems that the bars are very simple, no pretwists or machining as to a L/R twist.
Also, mine are in pretty good shape so I am hopeful they will last a long time. Note that if you swap a torsion bar end-for-end it is still loaded in the same direction. (If you doubt that, try marking a paper towel tube or something similar.) What I have read (in Panorama years ago) is that the torsion bars were actually all the same. They were marked for installation so that they could be installed back in the same side they came out of, because reversing the stress tended to lead to premature failure. If you can't tell which side they came out of, just re-install and hope. You have a 50-50 chance of getting it right, and even if you don't it may last for a while anyway. --DD |
| worn |
May 20 2022, 05:26 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,564 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I think the cotton washer is just to help hold grease in and dirt out. I believe it’s fine to reuse them. At the shop, the guys would cut some out of foam rather than take the time to get one or pay the Porsche price for a new one. Why not canvas? As in old blue jeans. |
Lo-Fi Version | Time is now: 17th April 2026 - 03:50 AM |
