| 73kg2.0 |
May 20 2022, 01:52 PM
Newbie ![]() Group: Members Posts: 3 Joined: 12-October 19 From: Denver Member No.: 23,560 Region Association: Rocky Mountains |
Odometer repair info is in here somewhere, but I can't find it.
Can someone please copy the link here if you know it? Thanks! KG |
| worn |
May 20 2022, 05:27 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,555 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
| 914sgofast2 |
May 20 2022, 07:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 791 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Look in the Lapuwali Classic Repair section of the 914 Forum for the info thread. However, if the speedometer needle works but the odometer mileage counters don’t work, there are two (2) possible failure points: (1) the odometer drive gear has gotten loose on its shaft and is slipping, or ;(2) the speedometer body support arms for the odometer gear shaft have worn oval and the gears don’t fully mesh anymore. If the problem is #(2), then you need another speedometer that isn’t worn out or you need to send yours to someone lime Palo Alto Speedometer for a rebuild.
| 76-914 |
May 20 2022, 07:27 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,866 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
| 73kg2.0 |
May 23 2022, 02:34 PM
Look in the Lapuwali Classic Repair section of the 914 Forum for the info thread. However, if the speedometer needle works but the odometer mileage counters don’t work, there are two (2) possible failure points: (1) the odometer drive gear has gotten loose on its shaft and is slipping, or ;(2) the speedometer body support arms for the odometer gear shaft have worn oval and the gears don’t fully mesh anymore. If the problem is #(2), then you need another speedometer that isn’t worn out or you need to send yours to someone lime Palo Alto Speedometer for a rebuild. Appreciate the tip. Speedo works. |
| 73kg2.0 |
May 23 2022, 02:35 PM
Thanks much. Got the Pelican article. Seems they still have to upload or reload images. Pelican is typically very good at this. |
| dr914@autoatlanta.com |
May 23 2022, 03:07 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,231 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Lo-Fi Version | Time is now: 5th March 2026 - 07:56 AM |
